I really do seem to have hit a brick wall (or should that be "buffers"?) with this loco. A shame because there's not that much to do, but it's all very fiddly. In fact, apart from finishing off the C13, I just don't have any motivation for active modelling right now.
However, yesterday I forced myself to start on the oil pots mounted on the supports at the front of the footplate. The Bachmann moulding is very poor in this area, with the brackets the wrong shape and size, very crudely moulded footsteps and the prominent hole in the wrong place. Apart from that, it's perfectly modelled!
The moulded version is seen in post 111, above. The brackets should look like this.
The two wire pegs sticking out are the mountings for the front oil pots.
Originally, I had these 3D printed but i think it was pushing the technology too far and the prints could not have holes up the bottom gland nuts for the pipes and I just couldn't reliably drill 0.25 mm holes in them either.
Recently, I designed a slightly simplified version as a fold up etch, which uses 0.4 mm O/D tube to represent the gland nuts. Yesterday I made up the first one and, keen to see how the finished item would look, I cut of the excess tubes using the etched jig to set the length. Oh no!!! I'd forgotten to fold over the cutting jig etch to double the thickness so had very precisely and neatly cut them to half the correct length - a purely self inflicted error that has left me rather despondent and not inclined to start on two more. Hopefully, that will come before too long. The ruined pot (mounting tabs not bent up) is seen near the top of the bracket photo.
Dave.
