Marches road A back story
Both the LNWR and GWR chose the same spot to construct their engine shed facilities, Giving that they both had equal operational powers on the joint line and their own lines that radiated away from the area, The shed operated as separate entities up until the 1930’s when making use of the loans and guarantees act the LMS and GW used a joint proposal to modify the shed and rid it of some of the more outdated structures, the biggest change seen the GWR coaling stage demolished and the 55’ turntable removed and a new mechanical coal hoist and 70’ turntable built, this was to allow the largest of the LMS Pacific’s to be turned and serviced, The rear part of the shed was very much a joint area of responsibility from that point on, however the GW used part of the loan to construct a new austere type of coaling stage at the front of the shed principally to coal it’s top link locomotives as the GW liked to keep its coal from getting damaged and broken up to much as often happened whilst using the mechanical hoist now installed. Thus provided a physical boundary between the shed fronts and a set of steps had to be installed so staff could access either side of the shed. In the immediate post Nationalisation years the status quo remained and marches road had two shed foreman’s and when the BR painters arrived at the shed they set about repainting using the new chocolate and cream on the western side and Midland maroon on the midland side. Part way through this a staff reorganisation came about after a BR inspection found that whilst the shed had good facilities the moral was low due to regional rivalries and a new single shed foreman was introduced and the shed finally became one entity. Regional colours had been dropped and a greater sense of cooperation promoted. From that point Western locos and midland locos used either side of the shed and it became possible to see a Princess ex works off Crewe shed along side an Old Oak King both being serviced together.
This layout / powered diorama is 6’ x 3’ about the size of a single bed which is how most of us start out in modelling with a board on our childhood bed. What this layout does is showcase a collection of locomotives and that’s exactly what the customer wants.
