Cliff Williams
Can I suggest you add a linking rod to the three separate fall plates underneath? They outers will drop and become trapped between loco and tender.
That's a good point, Cliff. I didn't do that with the split fallplate on my Black 5 as a result of which it's now vertical between loco and tender.Can I suggest you add a linking rod to the three separate fall plates underneath? They outers will drop and become trapped between loco and tender.
The only disadvantage is that the quantities tend to be rather more then we'd use on any single model, but just think that you won't have to buy any more for the next one.
Also, check that what you are buying is bare copper wire. It comes in a multiplicity of colours for jewellery making, and you could end up with pink if you are not careful.
