Scale7JB
Apart from a bottle opener .
I have to admit I won't go anywhere near a beer when I'm modelling, just not worth it..
JB.
Richard,
A tip I got from the late Colin Binnie many years ago for making hex fittings was to use a pin vice with a hexagonal body to hold the material when shaping when the hex body gives you an easy indicator of the hex sides. If your pin chuck has a round body, find a nut that will slip over the round body and glue it behind the chuck end.
Jim.
Re your scratch build unions, just wondering, would it be possible to make these available as lost wax castings not only for the kits but as listed detail parts
Bob
and then it needs cutting off the sprue and cleaning up with a file, 1 in 5 will probably bounce off the floor and disappear into the ether. Now I know how it's done I think I'd prefer to make them myself, probably no more work than drilling and cleaning a cast item. (edit: forgot to add being a cheapskate probably cheaper too.)I'll have a chat with the guys. The problem I see is getting the 0.45mm hole through. Casting starter hole dimples would not be a problem - asking people to drill 0.45mm through the length of the casting might be too much.
Hi Bob,
It's not just me then! I have become particularly adept at dressing small drills with a mini diamond sharpening plate to prolong their life.the hardest part about the whole lot is drilling the holes in the castings for the pipes. My drill attrition rate is high!
