john lewsey
Yes fascinating
When you consider the pollution caused by burning rain forests and big ships burning black treacle as they pass each other with similar cargoes, the enforcement of engine tier 'telephone number' emissions regs just seems a complete load of rollocks.
Rant over.
Never get THAT through an MoT emissions test.
You don't get that much clag from the Stena ferries... I hope. I'll be on the Hollandica Wednesday night.
You hope!, DFDs went and whacked the Ro-Ro ramp on Saturday big time.
forums.overclockers.co.uk/showthread.php?t=18522002
No official word yet, but looks like he over cooked it whilst trying to manoeuvre in very high winds, probably didn't take towage and paid the price.
Best check Stena Lines are still running as DFDs Esbjerg service is cancelled.
Regarding the smoke, you won't/shouldn't, ferries run medium speed diesels which burn cleaner, Stenna Britannica and Hollandica run at 500rpm and they use a much lighter grade fuel, not the thick black cheap crap some cargo ships use.
Container ships run at slow speed so clag up easier, I think max rpm on a typical container ship is around 80-100rpm.
Having said all that, here's a medium speed diesel clagging, mind she is at max rpm and full port rudder to make the tight turn.
Hot sh*t! I checked the Stena website and that says services running as usual – from the photos I'd say that was the next ramp along, towards Mistley. I think (ie I hope) the Brtiannica and the Hollandica have their own dedicated on/off ramp. If not that'll be a 2.5 hour journey for nothing.
But, thanks for the heads-up Michael!
Never managed to do the HSS run, shame, wished I'd just done a foot passenger there and back to sample it.
I suppose at some point I should get back to S7 modelling LOL, unless of course I'm going to model a modern dock scene with 7mm vessels....and yes....the thought frequently crosses my mind, more frequent than is good for my mental resolve!
Mick
I hope you don't mind me commenting, but I don't think your top wipers are the best method of getting power from the wheels to the motor. There are a couple of issues which could cause frustration later, one being that any pick up on the tread will collect any gunge from the rails so get dirtier quicker, the other is you will have to remove the body to clean the pick ups. I find I don't have to clean pickups very often, except at exhibitions in venues with carpet - a check at the end of the day will find lots of fluff. I suggest that you use Iain Rice style backscratchers mounted on a bus bar or strip of pcb fixed along the side frame. It looks like there is plenty of space between the inner frames and the wheels and it will all be concealed. Having the pick up mounted so it touches the back of the wheel or flange, in line with the axle, means you can clear any fluff with a pair of tweezers from underneath without taking the body off. I usually use phosphor bronze wire for the actual pick ups but you could use strip. Having pick ups on every wheel also helps keep things running smoothly.
That last post makes for a fascinating intro to the possibility of battery power. Got me thinking now (had previously dismissed it as most of my current pie-in-the-sky motive power modelling ideas revolve around small industrial 7mm engines).
It is a bit Heath Robinson and like most of this project, an exercise in what is and isn't practicable and I have zero issues taking it all off and trying something else if this does not workI really don't want to faff about with split axles and insulated horn blocks and accept that's probably the best method wholesale for collecting power. Nor do I want to employ plungers, I've had little success with them in the past sadly.
