S
SteveO
Guest
That looks superb Mick!
Fantastic work Mick, you don't half hang about. I take it you have somebody to etch your bits nearby ? Should have the standard five ready for the Christmas Party :thumnbs:
ATB Mick
What do you cut out with, a piercing saw?
Do the manufacturers do you a special deal on blades? Or is there a container somewhere with about 1000 missing? LOL
(The above is a joke, NOT meant to infer that you are dishonest in any way).
Hi Mick love the idea of what you are doing with your frames, is there any chance of you doing some Rebuilt Royal Scot frames and stretchers in S7 for me mate?
Len
I don't see any bodging going on here. I'm stunned you cut and fit all that without etching. I can't get gaps less than about 1mm wide whenever there is a curve involved!
Good idea with the boiler profile too.
David.
Hi Mick don't run your-self down your modelling is fantastic. have you got The Power of the Royal Scots by David Jenkinson in it there is some pictures of the workers building one of the Scots with frame details, these are for the original Royal Scot but with the wild swan book you could work-out what was different between the two. Sorry mate to keep going on about this, (Obi-wan kenobi your my only hope)
Len
Groan - oblique cones. I remember working out the net for cutting one out as part of my GCSE in CDT. What a pain. Still not all that easy in 2D CAD, but you may well be able to create in 3D and unroll it to create the shape? These days one has a trick after modelling German prototypes for so long (which tend to have very subtle cones in their boiler cladding) and it's very close to what you're doing at the moment...
Um, possible pedant mode alert required. Does your oblique cone give you a feeling of "frustrum - ation"?Groan - oblique cones.
Thanks Graham,Um, possible pedant mode alert required. Does your oblique cone give you a feeling of "frustrum - ation"?
I recollect seeing a method of developing a taper boiler shape in a book about model loco construction circa 1975... if of use to you Steph then I can try to find the book again - after all, there can be only so many piles of books through which I have to search!
