Moving onward, snatching time here and there were almost at the finish line.
Updated since last time.
;Other side brake rigging added.
;Correct wheels from Salters fitted, turned to S7, hubs reduced and axles modified to suit.
;Remaining sheet work on tender top, stream lined fairing and coal fence edging.
;White metal parts fitted, though springs still require the reworked hangers and fixings to complete, currently just held in place with double sided tape to see if I can live with them, may just opt for a set from Ragstone as replacements, also very tempted to whizz some up in 3DSM and get them printed, that way I have more control over the quality and costing, but requires more time....which could be utilised elsewhere.
;Replacement tank on under frame made and pseudo plate work to support it, supplied casting was too small.
;Weight added, now tops 600g, might push that to 1Kg depending on running tests tomorrow at Love Lane.
;Sound proofing added, drastically cuts down hollow effect and gives a better sense of mass when rolling.
;Dummy floor for coal space.
;Front end fittings added for water scoop, hand brake and valves etc.
;Buffers fitted, not happy with these as castings very poor so had to fill space around buffer and then drill to suit as buffer sloppy in housing, still some play and current sprung retention method is very 'Edwardian', two options remain, A: fix the buffers solid with glue once painted, B: rip off buffer beam, fit replacement castings and buffers and work forward from there.
Overall top view.
Side view.
Front end.
Rear end showing replacement tank.
Not happy with that brake on the right! Needs straightening, also requires insulated bar between left and right brake lower pins.
Under view showing pseudo plate work and new tank
Still to do.
;Rear insulated cross brace on brakes.
;Front brake lay shaft (possible Ragstone casting) and linkages.
;Front draw bars and simulated interconnecting pipework.
;Front footplate from 1/64 ply wood strips to give wood grain effect and more 3D depth to that area.
;Some form of electrical pick up, having opted for insulated axle boxes one should really opt for split axles, however I'm tending toward not splitting the axles and having alternate left /right collection, I.E. short out only one wheel per axle, left, right, left, right etc. Or, wipers.
;Spring hangers and fixings...or replacement Ragstone castings.
;Hooks n Hoses, after paint I suspect.
;Decision on actual loco to model, affects electric lighting fitting or not.
;Prime and blacken required areas.
;Paint n decal.
;Coal.
