That's a great reply, so what are the options for the correct tender as you said I want it in its 1963 condition
Steve, you need 5651 which is an A4 bow ended corridor tender with stainless steel strip, the main platform level difference between A3 and A4 corridor is the beading, however I think the corridor roof is quite different between the two types, especially in the coal space area.
The stainless steel strip is an important feature and often missed, ignored or not generally known about, most know it was fitted pre war and removed post war when the skirts went off the locos, but the tenders retained it. I think, and I am guessing here with out getting all my books out, that maybe one or two had the strip removed and just left the fitting lugs poking out from the bottom of the tender footplate....but I really must double check that to be sure, it's just a niggle as I'm sure I've seen some tenders with the fixings protruding and making the tender look really ugly.
Some photos to help y'all understand a bit better, these are off the web and copyright exists with original owners and the images have been cropped, the colour one is just superb and I've a handful from the same source, mostly around Grantham, but I cannot for the life of me find the site again, I'm sure it was on flickr and suspect the site has closed so the images are lost forever to the public.
First up a standard bow ended tender 5590
Now the bow ended with stainless steel strip 5651
Note deeper valance under the tender footplate and it sweeps round over the buffers, note also the larger curved rear steps, without checking my books I think these are only on the corridor tenders, but A3 or A4 or both or just bow ended I've forgotten.
Choices, not a lot really, if ACE do let you have a tender then start with that, the frames and running gear are pretty much identical over the whole fleet so the Hacette frames will suffice, you just need a new body, you could modify the Hacette body but note that corridor tenders are 'full' width, non corridor tenders are 6" narrower with a lip around the base of the tender, so your Hacette will have to take on some full fat coke and burgers for a while. The handrails will be too short as well, note both of the above tenders, the tender handrails match the cab handrails, the Hachette kit if true to the speed record will have handrails 3" too short....you will easily notice the visual difference.
The only other option is to scratch build or try and get hold of a streamlined A4 tender from someone else and then just bow the rear end widen slightly and adjust the side sheets to suit. As I've said before, I want to make some art work up for a range of tenders as I think it's getting a bit of a hole now for what's available, but they will be etches only, no castings planned as yet. I need a tender just like yours so your welcome to a set of etches if they meet your standards when I get them done, as you say, there's not much of a rush if your doing the partwork route.
Addendum, just read your considering the Partworks A3 tender, that'd probably work, it has most of the corridor bits and pieces you need, the front end might not be 100% accurate but then it's hard to see in there if you add the weather sheet
I have to confess, tender fronts are an area I lapse on, especially LNER Pacifics with their weather sheets and tight clearances. You will need to change the rear bulkhead, chop it off and make a new bow ended one from brass or even Plasticard as I think the Partwork A3 was plastic bodied? then you will need to add extra raves on the side sheets and make them higher over the corridor both in the coal and water space and on both sides. Finally get rid of the beading along the top and back of the tender.
I do keep looking at the Partworks A3 but am put off by having to clean all the brass, I've heard it has the same lacque as the A4, but that might just be urban myth, also the firebox looks woefully narrow and the cast footplate just seems a bit chunky, but other than that the rest of the model makes up really well, there's been a recent rash of them on the bay of E, some go for silly money but one or two were in the low £300 bracket, which isn't too bad a price really.
