Mickoo's BR modelling
Steve Cook
But it IS.
Unless you are building a static model suitable for placing in a museum, what's the real point?
Yes, YOU will know it's right, but outside of sites like this, how many others will? Or care? There's a limit.....
Its Mickoo's hobby, Mickoo's project and therefore he should pursue it in whatever fashion floats his boat and makes him happy :) I would have thought that whatever anybody else thinks or cares about it is irrelevant - worrying about either of those is the road to madness.
Anyway, this place is for sharing both the joy and frustrations of building and making models - that strikes me as more of an an individual pursuit, rather than about pleasing others.
Steve
... outside of sites like this, how many others will? Or care? There's a limit.....
How many will know? Those who pursue such details probably do not care about an answer to that question. For such modellers the driving forces are the desire to achieve and the satisfaction from the result - in such cases the only limits are those imposed by technology and the ability to see a way forward.
Pugsley
That's the crux of it right there.
Probably no-one, but that's irrelevant.
I can sympathise with Mick - I've spent a few hours this evening going over drawings of a Cargowaggon, that I didn't have before I'd mostly completed mine and agonising over whether to alter a couple of details that were 1-1.5mm out on scale. Given that I'd estimated the whole thing from a basic dimensioned diagram, and photographs, I was quite impressed with how close it was, however it still isn't right.
In the end I decided to leave things as they are - to change this part would involve reworking the whole end, so I've left it as an acceptable compromise.
There was another bit that was 5mm out - that's being attended to :) No doubt more will be discovered over the next few days.
But it IS.
Valid points all, but even a casual glance at an A3 will revel no massive slot for the reverser shaft or the missing rivets, let alone the misshaped ones in existence.
It's also true that once you know something you feel obliged to add it, therefore ignorance truly is bliss!
Put another way, would you add an undersized chimney or dome, or put on 6' 6"wheels, no you wouldn't so why add under scale rivets, we're not talking stuff you don't see, it's plain to see and anyone with a passing knowledge of A3 will notice.
Alcazar, your right, only I KNOW, but as I'm building the model for ME, then surely my views are only ones that matter?, I'm not building it for anyone else or their approval so why would I accept their criteria?. In short who am I actually building models for? you (collective) or me.
Richard, your right I could, but the thought of drilling out all those holes fills me with dread LOL, the round heads I can semi accept, it's the bleedin great flat head ones that I need to find, and inside the frames, it's the massive bolts and studs I need to find. If I'm going to go to all the trouble of smoothing off the existing ones and adding scale hardware or some such then may as well CAD up new frames with half etch holes that allow larger sized rivets to be punched.
I've the DA A1 to do and suspect that will fall into the same pattern, in which case I'll pre drill all the half etches so that the rivets are larger when punched. To be fair, some of my issues are due to the previous builder and some are down to the kit, I won't lay all the blame at Davids door as overall the kit is very good, more a case of I'm wanting more than the basic kit can accommodate. I think yours will be just fine, as will many others ;)
Here's an example of the rivets behind the leading wheels
Not small or invisible even if you squint and try your hardest to ignore them! The solution is a combination of half etched and punched
I have finally worked out after months of hand wringing that I'm one of those that has trains he plays with, as opposed to those that play with trains, thus rivets (visual)....literally are important to me, those that ascribe to MRJ I point you to N0 232 page 173; that is what makes me tick, insane or anal as it is if I make one model and take one photo even half as good as that I'll be a happy man.
I've also be toying with a layout proposal and had almost finally settled on a version of Belle Isle, but slightly modified so that I may....if so inclined amend to OHLE or WCML etc, but having seen some tasty detailed depot shots and now in a quandry as to whether I should build what would be a 'moving' layout with fiddle yards or a shed based layout with detailed models
My modelling genre is more than just a few rivets here and there, it's what will form the nucleus for my future. Either way, doing nothing is not an option LOL.
Pugsley, I fully appreciate your situation and compromise, all modelling is a virtual compromise, only the individual can determine the level of compromise that will let them sleep easy at night.
Like you, a difference of 1-2mm on an already built model I'd let slide, more than that it'd be a rebuild, but if the information was available before hand, then it'd have to match that data;)
Ressaldar
Hi Pugs,
that will be time well spent for when you compare the Heljan offering when it surfaces, with your scratchbuilt model:thumbs:................and letting us know your findings of course.
Dikitriki
Totally agree Mick
Overseer
Mick, I haven't checked what is on p173 yet but we could probably have saved you the months of hand wringing :) , based on the amount of effort you go to to find out what the details should actually look like (EMD cabs etc, etc). Although being told isn't as satisfying as working things out for yourself. I have never found a reason to look at LNER pacific frames in any detail but it strikes me that those flat rivets are just asking for a half etched overlay on the outside of the frames. That would hide the unwanted holes as well.
oldravendale
I'm in the same camp as you, Mick, but as my knowledge and research is never as great as the detail you have clearly gone in to here a lesser result satisfies me, which rather confirms your suggestion that ignorance is bliss!
However, looking at the photo you supplied whoever is rebuilding that loco really should get another set of bogie wheels cast and it will be a bit bumpy going round corners with only those wooden bearers to slide on. :)
Brian
Gotta build a loco shed...
Got plenty of engines to help you out at exhibitions!
JB.
It's looking that way, but added to that I like scenery and well laid track, signal boxes, signals and bridges too, hence focusing on somewhere like Belle Isle or Princes gardens where trains move but slowly and sometimes stop waiting for platforms (fiddle yards) to clear, as well as lots of light loco moves. But! I do so love the nitty gritty crunch underfoot of ash and cinder at depots:thumbs: There is clearly no hope for me LOL, it's a mind game that will keep me busy for a while yet.
This is true, a half etch overlay would be the answer, inside and outside and if your going to the trouble of all that then you may as well get the rest of the frames on the same art work. There's little mileage in just getting one small part etched, it'd just make the rest look sub standard. As I'm also modelling in S7 then all the stretchers need redoing anyway; but yes, your right the 'correct' way forward from this point is a new set of CAD frames and stretchers. The rest of the kit (if the A1 tender is to go by) I.E. the upper works tend to go together quite well and require a modicum of care and detailing to bring them up to a high standard.
I haven't checked either but I suspect it's the John Dorman[?] 7mm King on shed.
Certainly is and if they had dropped the exposure a couple of stops you would be very very hard pressed to not think that was a real loco, and there's nothing there that anyone here could not do with a little bit of hard graft and dedication. However, to get to that level your foundation model has to be sound.
Brian
Brian, quite true, we all have differing levels we are happy with, there's nothing wrong with that, that's what gives this place it's broad spectrum of interest ;)
I think that is the 'Flintstone' variant of A3
Anyway, back to the A3 frames and some details on my previous ramblings, Richard you might want to look away now ;) As far as I can ascertain, the only kits that get this area right are the Finney A3 and A4. The rest of the LNER Pacifics do not as far as I can ascertain, I don't know why as it's not difficult to achieve and requires but a few strokes in CAD work to replicate.
The genesis of LNER Pacifics is the A1 class and virtually all locos from this point follow the same rear end.
A1 chassis
The red line is the main frames which run the full length of the loco, the green line is the strengthening plate (not the one I mentioned earlier, that comes later and is ahead of the rear axlebox) that bridges the joint between main frames and Cartarzzi extensions shown in light blue. Thus there is a distinct step in the frames when viewed externally and the bend outward is some distance from the wheel rim.
In orange is the general line that most kits seem to take, they kick out almost right behind the real wheel rim, and as most kits are designed for finescale, the angled bit will be the wrong size to compensate for the narrower frames and incorrect bend line.
On the DA kit the width of the Cartazzi extensions is also wrong, it's width is 45mm which is 3mm too wide. I can see why it's been done as it allows more sideplay in the rear Cartazzi axle for tight corners, but it does mean that anything attached to them, steps, axleboxes, pipework or linkages does not line up with the body above.
Moving onto the A4 chassis
Exactly the same principle but the Cartazzi extensions are a little longer at the front end, only a few inches mind.
Finally the Peppercorn A1 where things change
On the Peppercorn A1's they moved the reinforcing plate outside of the main frames, this means the main frames are a few inches narrower (3' 11¼" as opposed to Gresleys 4' 1½" between frames) as the extension plate has to fit behind the real wheel, the Peppercorn A2 is identical, the Thompsons I plan to research and get the GA's from NRM in the new year.
I think this is something I'm going to come to grief with when I get round to building the V2..
All of the engines I've built so far don't exists anymore, so a little educated guessing is perfectly acceptable, whereas with an A1/A3/V2 etc...
JB.
Spot on, I'm fully in the same camp, the Fowler 4P tank is best guess from photos and the GA's, but high profile locos that can still be accessed and researched today need that extra level of detail.
I was chatting to some work mates at our Xmas dinner last night and they were taking the pi55 about toy trains and anoraks etch and all this detail blah blah blah, they weren't so keen when I asked them if they would play golf or fresh water fish with substandard equipment. It would seem that what ever your hobby, if your that way inclined, you will go to what are basically unreasonable lengths in others eyes to satisfy your dreams.
The V2 follows the Pacific format, which is fortunate as I'm looking at modelling a A2/2 at some point and they're basically V2 rear ends so this area will be the same.
I think the Finney kit will be accurate in this area if the A4 and A3 (photos I've seen) are anything to go by.
Phew, my A3 is based on the Finney kit, so I shall assume it's correct:)
Excellent information as ever:thumbs:
Richard, your rear end will be fine on the Finney kit, though you may run into issues with the lightening holes depending on which loco you choose, I think I've got your photos from elsewhere and can't see the rear oval hole blanked off.
In a basic break down locos were built with four oval holes up until 1929.
Post 1929 locos had four round holes in the frames. (60084-088, 099-101)
Post 1933 locos had only one hole at the front. (60035-043)
That covers new builds but rebuilds are a minefield.
Fundamentally the change over date is 1933, before that date the replacement front frames had the one hole ahead of the rear driver and the oval hole behind blanked off, all other holes except the very front one were not cut.
Post 1933 rebuilds had only one lightening hole at the very front.
Clearly Flying Scotsman had her frames rebuilt before 1933 as she has two round holes and one oval blanked off, I will slowly go through all my photos and books and try and see which other locos had pre 1933 rebuilt frames as RCTS does not detail that information.
I'm concentrating on BR so you'd think things had settled by the late 50's but Doncaster was still rebuilding front ends as late as 62 (60100 & 60112) so what ever frames they were running with goodness only knows, could even have been original four oval holes or the newer four round holes or any combination of the above!
Moving swiftly onward the solution was as simple as it could be in the circumstances, simply make the wrong DA frames the right shape and add new Cartazzi extensions, all went swimmingly until a 6'8" wheel was fitted to the one completed side. In my innocence I used the end of the frame where it curves down as the fixed point and the extension fits here where the curve ends. On the real loco this is a few inches outside of the wheel rim.
Green is the wheel rim
Red is the correct frame line
Blue is the Cartazzi extension bolted onto the outside
Orange is the DA frame line
Thus the blue frame extension is too far forward and impacts the wheel rim, end result is to trim it back as best one can and tidy up, bearing in mind it'd already been soldered on.
The second extension was made smaller to begin with.
I've marked in red where the frame shape should be and the upper frame has had all the rivets aft of the rear axle removed, they were just appalling, the idea being to use scale hardware ones in their place.
The question now is how much further does one prolong this folly, it's quite clear to see the nice rivets on the brass Cartazzi extensions, even through 20 thou brass and with no half etch relief on the rear. Complete new frames in 20 thou brass would probably be a couple of evenings work and then add in new correctly shaped Cartazzi extensions. Rather than make rash decisions I'll just lightly tack the stretchers in and throw some wheels on and let it ferment for a few days ;)
Cransford
Further developments, discussions at Sudbury at the last meet drifted back and forth on track issues and the lack of FB chairs and clips. In early BR diesel days much FB rail was laid on wooden sleepers and used a variety of chairs one being this 'staple' type.
Talk revolved around perhaps getting the chair 3D printed and the staples as an etch that is pushed up from below and then formed over to the correct shape.
It is acknowledged that the etch staple may not hold the track all of the time, so some additional adhesive between the rail base and chair might be prudent. Having 'discovered' some of these at work (as well as other types) I can now measure and see if the whole project is feasible.
View attachment 23574[/QUOTE]
I suppose I should say hello to begin with as a newbie. I'm getting closer and closer to taking the lunge and doing something in 0 gauge. Have been digesting the forum with glee and dmiration for the skill of those who know how to do it! Got this far and noticed the photograph of what is a BR1 baseplate and suggestions bout reproducing. If you're still thinking about the prospect, I'd be able to provide some further information - let me know.
Well, the struggle continues, I decided to keep the kit frames, there's so much else wrong with the kit that I might as well just fudge the rest and ignore the previous errors.
The next stage was to bend up the footplate, I have zero confidence it's even close to the right shape so fully expect a whole new firebox will need fabricating to suit the probably fictional curves. On the real thing the footplate is higher than the main frames by about 6", a couple of mm in our case, the kit is made to have the footplate the same level as the main frame tops, of course then the drop link bracket are in the wrong place. To compensate the footplate is bent a little higher in the middle and now sits at the right height, however, being one piece what gets taller must get shorter so the frames have had to be shortened by about 1 mm to allow the buffer beams to fit correctly.
The next big problem is the cylinders, totally the wrong shape, about the only dimension that is correct is the width across the piston covers, that over the valve cover (the A3 has a stepped cover....below) is too narrow, by 1.2 mm. Now that might not sound much but it gives a casing with massive bulges around the pistons, the A3 cylinders do have a bit of clenched fist look but not this much, it totally destroys the look at the front end. The second issue is that inboard the curve around the piston continues, why I have no idea as it's all well clear of the bogie wheels.
Cylinder front view, the low light and grainy picture clearly shows the additional fillets to get the right shape of the cylinder front face.
Cylinder rear face, yes it's supposed to kick up like that, I'll need a small fillet to bridge between the clothing and rear face in due course.
You can also see the additional pieces higher up to give the correct width over the top part of the cylinder, however the kit valance is designed for the narrower fit so I've had to thin the top part to get the cylinders to just about fit, I may need to thin some more before the final clothing sheet is fitted....and then thin the valance here to get a neat snug fit.
All of that I could handle until I re-looked at the drop link bracket, I'm kind of guessing it's 2 mm too small due to the footplate errors above
The result is when fitted it sits much too high in relation to the footplate and is the wrong shape, the red line should pass through the drop link hinge point.
You'll have to excuse the slight bend in the footplate, it's partial kicked up by the cylinders not sitting quite flat under the valance and partially due to the wide angle lens.
I've also noticed that the motion bracket is going to need quite a lot of massaging to get half way decent as well, maybe new brackets all round might be the answer.
As a bonus, the incorrect upper slot in the frames will be covered by a substantial drop link bracket support....not supplied in the kit...as far as I can ascertain at the moment.
