James Fibbens
Member
That is an excellent idea. It's been a while since I built anything, however I recall a great deal of faffing about getting motors/gearboxes to fit into loco bodies.Here's something a little left field triggered by a discussion today on Facebook about motor & gearbox clearances.
I've been meaning to do this for a long time now and today finally pulled the proverbial digit out. I'm not sure how or when others fit their motor gearboxes or test for clearances; but I frequently find that one orientation that's perfect for the chassis suddenly needs moving when you add the body, ash pan, brake gear.....insert excuse here......
Even when fitted you shouldn't really be soldering and spattering hot flux around drilling or grinding with it fitted, consequently it ends up going in and out during different stages of the build. In the case of the King I had to leave final positioning until the footplate (and at least firebox shell) was completed before I could work out clearances and final position, resulting in some hacking here and there to get the best position.
The upshot of all this was some sort of crash test dummy motor gearbox, one that you could install and work around, check clearances, grind, solder, drill and check side play with ill effect.
The first test one came out just fine, in this case the Slaters SG38 unit, my 1:1 unit has the older slightly longer motor fitted with the flat sides. Slaters latest drawing on their site shows a shorter cylindrical motor, which is what this crash dummy represents.
In time I'll do all the most popular ones I use, building up a stock of units I can just throw in with little care if they get damaged during the build.
I tend to make my driven axle rigid, especially if it's the rear one, so my motor fixings are really simple, two transverse bars that simply stop rotation of the unit under load, hence the solid gear box on the dummy.
Sometimes the motor is designed to float so I make a hook/claw that grabs one of the gearbox tubular spacers. Thus Mk II will have a slightly hollow gearbox with those spacers in the right place so you can fabricate the mounts with the dummy in place.
They also allow you to test several different types/designs before splashing out and buying one.
Have you considered adding a couple of mm to the envelope of the thing, mainly on the motor, to provide a little bit of extra clearance for when the actual motor is finally installed? You could also add a range of dummy flywheels, although perhaps its easier to just use the real thing if your temporary motor shaft will allow it to fit.
