Actually the answer is on page 78....only kidding
I'm sure I've written how I do it before but maybe now is as good a time as any for a refresher.
In a nut shell I find other hornblocks/guides a right pain, it's probably just me, but etched ones rarely seem to fold right or the slots for tabs are too loose/tight and cast ones are often misshapen and take forever to dress smooth. They all also seem to be too wide, actually they're probably to scale but the narrow frames for O fine makes them over sized, especially if you want to fit inside motion effectively.
The solution is something Nick and I have discussed over many beers and we kind of wishy washy had this idea of making our own (etches or castings) but over time we worked out you really need nothing more than some brass angle (in my case 2 x 2mm but I think Nick uses 1.5 x 1.5mm). The concept really took off when I got deeper into 3D as we could now cover the ugly angle strips with nice detailed cosmetic prints over the top.
Essentially it's just two angle strips up the sides and one across the top, onto which I solder a 10BA nut and then use that as a guide to drill the angle for the adjustment screw. The 3D print has a corresponding recess to accommodate the angle strips so it sits flat on the frames.
More recently I've been adding dummy axle box faces, these strengthen the horn guides, especially those with no cast header seen on more modern engines, without the axle box the horn guides up the sides have a tendency to splay or not adhere well. The axle box face has a pocket behind to allow the metal one free movement and a elongated slot to allow the axle to move up and down.
On the 4F I made a further change by burying a 14BA nut in the spring hanger bracket of the cntre axle; it actually needs to be a little deeper so I'll make a revision and print the final ones off before it goes for paint. That allows the 3D print to be removed and the axle box dropped out. The others are all fixed and have a small rivet/pin passed through from the inside and soldered outside to give a good mechanical fixing; I've been finding of late the adhesive can fail if rough handled or any flexing is present.
They take a bit of extra work but are actually quicker and easier than messing around with other etched or cast ones, plus you're in control of all aspects so you're not trying to fix issues caused elsewhere by design or manufacturing. The angle is also cheap as chips and a couple of lengths will do several models.
