Correct, a little is skimming it a bit thoughDave,
The tender story is a little convoluted as there are the three "Stanier" modified high straight sided 3500 gallon Fowler tenders, or "modified old standard", one of which, as you mention, ran behind 48600. Additional to this are the Stanier 3500 gallon tenders, which are basically a 4000 gallon tender type but on a 6'6" + 6'6" wheelbase. These latter type were paired with Jubilees from new and then of course moved around. However, I have also seen mention of 10 high sided flush tenders, but don't have access to my reference material to check this out.
Here's a photo of 45660 with a Stanier 3500G tender:
The problem I have with the three specials (9000-9002) is the brake rigging. On the Royal Scots the rigging follows Fowlers compensated linkage style rigging but (and I haven't checked the tomes) my understanding is that the chassis were retained from the old Fowler tenders and new Stanier bodies fitted.
However, Staniers Pacific tenders have a more streamlined single rod each side front to rear, looking at the frame drawings they match closely to the later Pacific tenders and 9000-9002 were rebuilt with the standard Stanier 4000G tanks.
It's a logical leap of faith to assume the first three had the same linkages as the following examples and were precursors to that lineage, despite having bodies that look like Fowler tenders. Either way I'll hang fire on that detail as the elves carry on searching for proof.
