So we're on Mk II now, quite a few evolution changes and a new sub design to fit direct onto Slaters axles. I've also added the balance weights and dropped the idea of the rebate at the front to fit into the front retaining lip; in the end I just machined the front lip back to 0.2 mm (2nd picture) thickness, it looks so much better.
Pressing in the cores is still fraught and some damage invariably occurs so I'm probably going skim some more off the rear retaining rim (we're talking 0.1-0.2 mm) so the core just 'snicks' in.
If I used a more pliable resin that might not be necessary; one thing to try is a mix of FNG with tenacious to achieve just that, you do loose a little detail but there's virtually no detail on wheels to loose so it could be a winner.
Mk I had a 0.1 mm run out and that was consistent with the axis of orientation (SLA printers naturally want to print banana's is a key thing to remember) so it was a simple task of moving the axle aperture in the opposite direction by 0.05 mm, run out is now 0.02-0.03 mm which I can live with.
The next problem, again linked to the way SLA printers work is a slight wobble, the axle to wheel is not quite 90°, it's about 3-4° out so the task now is to find in which axis it's out and then reverse tilt the axle hole in the core; that way when it prints it'll be a true 90° to the wheel.
You can of course easily counter that with the solid axle version by chucking it up and reaming a pure 90° bore, you can't do that with the Slaters square spigot fixing.
One final tweak was to rebate the heavy duty crankpins so the enlarged boss sits just proud of the wheel boss. The Slaters set are drilled and tapped 12BA with top hat bearings as is the usual way; I prefer 10BA and tapped top hat bearings so that'll be a third sub variant.
I've not fully cleaned up the rear faces, no need as these are going straight in the bin.
More to do.......
