Mid week update, quite a lot going on so first the Princess Royal.
Slow but steady progress, you spend hours doing bits and nothing changes, then suddenly it leaps forward.
I managed to salvage the boiler, I still need to take a bit off the firebox front plug so the boiler barrel sits tight up against the throat plate, but other than that no real dramas.
The kit middle cylinder cover is too narrow to fit between the frames, it's only 0.5 mm but it might as well be a mile, nothing for it but to scratch build a new one. What should have taken about 30 mins of decusping, forming, adding detail and fitting took rather much longer.
One thing to watch for is the two small handrails on the frames above the footplate, each side of the middle cylinder block, they were not there on roll out and appear to have been fitted a few weeks later, that means some wire plugs to fill the holes and dress smooth.
The white metal bogie bearing brackets/pedestals didn't survive the bogie pivot stay reworks, I'm kind of pleased about that as they were a bit naff and didn't fit into the frame recess very well at all. In hindsight I should never have fitted them as they let the side down badly; replacements are currently being fabricated, part metal for strength, part 3D for detail.
Part II is the arrival of some etch work, the Stanier high sided tender sides came back, pretty good all round so I can finish that off over the next few days and then start the chassis.
I did hedge my bets and two two sets of sides, one with half etched rivets and one full thickness with half etched rivet indents to punch out. Both came out fine but what I didn't spot until three days after the order was being processed are an extra line of rivets on the RH side.
These are for the fire iron tunnel which became evident when I found a really good clear image of the RH side, I'll just manually punch these out and then add the tunnel inside the coal space.
The other piece was a huge bridge for The Derby Line, the remit was just for the detail and fiddly bits, the plate work and big flanges will be cut by hand.
Quite a lot is back to back laminates, a, for strength and b, to add punched rivet detail; it'll be interesting to see Tony build this up and I'm half tempted to get one just to build myself, no need for it but it'd make a nice palette cleansing project.
