Because......if you look at the last photos, you'll see that the screw is trapped from below by the front spring beam and equalising bar to the front pony, it's also soldered to the cross piece as well.Ermmmmm.... as silly as this sounds why not use a permanent marker to draw a line or colour the excess pony pivot screw thread, dismantle it, put a nut on the screw up to the marked line/area, cut of excess thread, clean up, remove nut and replace the shortened pivot screw in the chassis.
Saves having to cut the excess thread whilst it is in the chassis.
To remove the screw will require dissembling the front springs and even then the cross beam passes through two lugs on the frames. To remove that will require one side frame to be separated from the front stretcher/platform and probably the motion stay further aft.
The only way to get that screw out is a frame strip down or cutting the cross piece it sits in and then working out some bodge to get it back in neatly.
Anyway, the job has already been done, I simply nibbled it down with a ball ended cutter and then flattened off the thread, so all is good. The only ugly bit is the end of the thread, the rest of the model survived intact
![Thumbs up :thumbs: :thumbs:](/styles/default/xenforo/smilies/thumbsup.png)
