David, not a difficult balance at all
![Smile :) :)](/styles/default/xenforo/smilies/smile.png)
, the customer lays the ground rules out and that's what you stick to.
I post copious images as the build goes along, here and Facebook, therefore there are no hidden surprises once the box is opened at the end of the build.
The most important part of any build is harmony, there is no point adding uber perfect sand filler backing plates if the deflector has square etched on beading (that detail really pi55es me off for the record), the cab is the incorrect profile and width. In the end you virtually rebuild the majority of the kit, aka the Warren Shepard County.
We also have to remember that some models are going to be working models, their view distance could be 6 to 10 feet away or even in the garden, sand filler backing plates that are 0.75 mm over size really isn't an issue
If, at the end of the day, the client really decides that the backing plates are too hideous, then it'll come back here, they'll be removed, new ones fitted and the paint repaired, not at their cost either.
However the problem will go much deeper, smaller backing plates will have to be moved back to make sure they just clear the boiler cladding, this will then reveal the great big ugly half etch trenches in the footplate used to align the cast ones.
You now have two choices, fill those ugly slots and try to blend them flush in among all that raised rivet detail, or make a new footplate with etched slots to take etched tabs on your new backing plates.
So you see, changing just one small part often has larger implications that go much deeper.
Regarding kits, never sell yourself short, some of these kits are getting long in the tooth, the A2 is 15 years old now, what was acceptable back then, not only in quality, but also in fit is often not acceptable these days.
I'm glad my dabblings are helpful, that's part of the giving that a great many others do here as well, I had to learn at one point, still am, so it's only fair to pass that along. Besides if I can forewarn others of little issues and save them time, then all good and well, quite happy to fill my swear box up if others remain empty
![Stick Out Tongue :p :p](/styles/default/xenforo/smilies/tongue.png)
