Finally! Inside motion all fitted to the 4F.
It needs a lot of running in and there is a little tight spot that needs chasing down, plus the right hand valve rod has a little kick as the pin in the expansion link is a little loose....read cast expansion link slot too large, a poke with some suitable implements will solve that.
It's a real mish mash of parts, none (other than the new motion etched bits) is designed for this engine, it'd make any East end chop shop boys proud
I do need to rejig the cylinder block, no matter how it was cut and shut the narrow frames really hampered the internals, along with castings just too fat to fit in there, consequently the valve linkages and alignment is slightly out, each needs moving onward by 0.75 mm to line up with the motion.
I had to loose the inner lifting links, there just isn't room in there and the expansion link is the wrong type for this engine with only one link pivot point, there should be two, one each side.
Apologies for the shaky video, it actually runs better on the track, something I find with most engines actually.
New motion bracket and valve linkages.
All fitted up.
