michael mott
Wow! if I was independently wealthy I would commission you to do one of those GWR Dukes in 1/32, you might not be a fan of GWR but I am.
Outstanding work sir!
Michael
Michael
It's not that expensive Well that could be relative I supposeWow! if I was independently wealthy I would commission you to do one of those GWR Dukes in 1/32, you might not be a fan of GWR but I am.
Michael
You give me too much credit It did come out nice but award winning, I don't think I'm at that stage yet to be honest.The 'King Arthur' model just ooozes class. Magnificent....It could win cups.
If I can, you certainly can!You give me too much credit It did come out nice but award winning, I don't think I'm at that stage yet to be honest.
MD
Cheers, you have me mistaken for someone else I fearVery nice Mick, but for a minute I thought you were building a Craven's DMU !
Turned tanks ends would be better, or complete 3D tanks.Great to see the Bulleid`s progressing Mick. Your right about the white metal castings, i threw mine in the bin and fabricated the TIA tank and turned the tank ends. Hope to see some build pics for the loco front ends and casings.
Adhesives are a valuable weapon in ones arsenal.Wow it almost looks like you have given up on the invisible solder and resorted to glue
Michael
'working smarter not harder'
Well there's a little trick there, two actually.How did you fix the stays on the insides of the top of the tank sides? I had to make several contributions to the swear box while trying to get those at the front in place.
Yes please, thank you.Well there's a little trick there, two actually.
I'll try both ways on the next sides and post photos if it'll help.
Mick,I tend not to tin the rib edge that goes in the slot, I think if I did then I'd get 14 out of 14, another way would be to place a sliver of solder in the slots and warm with a micro torch so that you get a thin fillet in the slot, then when holding the rib in place and heating from the outside it should flow and grab. The trick will be to not fill the slot or else you will loose your positioning
