Small update on the Finney7 BLP build, most of the time has been spent on the front end and tuning the middle cylinder block fitment.
The fit and form is fine, just need to add some details for the final rendition, the pressure relief valve will go on the print but the drain cocks will probably be brass castings if I can find some.
I've also found a photo that shows the sheet steel above the upper V notch on the bogie pivot stay is missing at the rear, a new stay is in the printer right now.
The big out of scale stay to form the front axle pivot for compensation beams set up does really get in the way, you could remove it and go for individually sprung but then you end up with no strength in this area and large slots in the frames to fill. There is a internal valve gear cover up under there so that'll hide a bit of it.
You need to hack the slide bar bracket a bit to get the cylinder block in but it is achievable.
The next big print is the leading spring hanger fixing and stay, complete with brake cylinders and bell cranks all in one unit. That will close a lot of the open space up around that area and add visual mass.
