Apologies. I’ll continue.
I think it looks okay, and better than ‘the gap’, so will glue some together to an appropriate length for both sides, which I’ll secure to the cast iron beams rather than the roof, which will need removing and repainting anyway. During my search of the shoe box, I also occasioned upon a Peco downspout or two, so might even add those at the ends somehow.
I’ve also amended the title of this thread, as - I think anyway - it’s the portability of this design which makes it a classic, the hinged section firming probably the primary part. The problem I have with it (and which has been nagging me for some time) is that it’s unwieldy for two reasons: first, the weight of the baseboard section being opened/closed forces it to meander from its plane, which can place undue pressure on the hinges unless great care is taken to control it (what the long term effects of this haphazard procedure will be, heaven only knows) and two, due to the height of the bench on which it sits, the layout cannot be folded without striking the ceiling, thus I have to ask for assistance to lift to the floor before facing the first challenge!
Unfortunately, this isn’t the only issue. Followers of my thread may remember - as I originally suspected on fitting them - that the ‘bling’ catches either side, which not only draw the sections tightly together but are supposed to ensure alignment in both planes, gave up the ghost after only a couple of assemblies, requiring post assembly remedy in the form of an old baseboard connector I had lying around. Of course, this would have been easier during baseboard construction as I suggested, but my - ahum - assistant was eager to push on…… Anyway, with the assistance of a drill section add on and the layout firmly braced by a screw through the overhead bearer and a brace formed of a two by one off cut, it was eventually fitted:
However, I still wasn’t happy, as threading the bolt through the hollow dowels wasn’t as fluid as it should have been, leading to concern that the frictional force would eventually lead to the dowels becoming a loose fit (it really was a pain trying to ensure the drill hole was perfectly horizontal, despite removal of wooden bearers and electrical sections which impeded progress).
So what gives?
Well, somewhere stashed away in yet another box stored in my railway room, are several hinges that have had their pins removed and replaced by removable bits of wire of suitable diameter, and which were themselves removed from an old, unsuccessful layout. Fitted a la Barry Norman style i.e. to the sides and beneath both sides of the joint, they provided stability in both planes, and which I have to admit, never failed to do their job in the umpteen times I had assemble and disassemble it.
So, when I’ve eventually completed my roof tiling task, I’m going to take a break from model building, and address the problem once and for all.
Hence, the amended thread title.
Cheers.
