Thanks to Mick for the sight of the various drawings. They've already proved their worth, as I shall explain. Also, thanks to Brian for some offline information. It's all very helpful. It's quite amazing how much research material you need, even though you think you have a fair amount on the shelf!
I've already noted how some things are in the kit - and others are not - but not mentioned in the instructions. This can be frustrating at best. It's obvious the kit has been updated, and the paperwork hasn't kept pace. Onwards and sideways!
I spent a while this morning refining the bunker details. Rather happily, my guesstimate for the backplate brackets being 1ft 6in from the centreline proved correct according to the drawings.
![Thumbs up :thumbs: :thumbs:](/styles/default/xenforo/smilies/thumbsup.png)
I thinned the angle down a bit, as it did look a bit clumsy. The water gauge will be fabricated at a slightly later date. I checked the photos of the engine I'm trying to build, and it does have the gauge. I'd never have spotted it without those Flickr photos from the KWVR.
After that, I turned attention to the tender underparts. A spot of riveting, some laminations, and some folding later, I have the main outer frames (still needing their overlays) and the floor under way.
With the tender front posed in place, it's all beginning to look the part. After working on the MMP Mk1 kit, I had become accustomed to in-built tolerances for the etching cusp on edges. My experience of JLTRT etches is one does need to clean up the edges for a neat fit. This can be time consuming, but it is well worth the effort.
The WD tender is an imposing fabrication in real life, and the various bits of brass seem to follow the prototype quite well. Odd, then, things like the brake standard extension under the footplate is missed out. Easily resolved by a short length of brass tube, though.
The real thing had self-contained buffers, and to be fair the following problem isn't because JLTRT has got it wrong.
Trial fitting the rear buffer beam shows the tender frames run slap down the middle of the holes where the buffer castings go, as confirmed by the GA. Some creative thinking may be needed to overcome this. An immediate thought is to fit the castings and file them flush to the back of the beam, then engineer a wire springing system to fit within the frames. I certainly can't use the standard spring-and-nut system, nor can I cut holes in the frames.
I haven't really set any targets with this build, but it might be nice to get this tender on its wheels by the end of the week. I'll see how it goes.
