Today I asked Laurie at JLTRT if he could send me the missing part of the instructions for the pony truck. To be fair, this kit is quite elderly, and things have been improved and updated since this copy was produced, though I was told the instructions are still rubbish! (From the horse's mouth, so they do listen!)
The replacement boiler casting also turned up today, so I now have most of everything I need to finish this loco. Famous last words!
The frame erectors came back from their Caribbean holiday today. Plenty of careful filing for fit, and I discovered the original builder had managed to break one of the folds. I guess that was the point where the extra set of frames etches were acquired, only they didn't have the spacers on them, and the builder gave up and bunged the whole thing on Fleabay or something.
Anyway, the problem is not as bad as it sounds, just needing some tender attention with the hotting stick and a square.
Once I'd got most of the frame spacers attached to one frame, I could test fit the other frame and try the cylinder block for size. There followed some mild head scratching as I pondered where some extra space might be achievable to clear the leading drivers.
Note the R on the cylinder stretcher? I think that was supposed to designate the rear of the block. Indeed it is possible to fit the cylinders into the frames the other way round, but the eagle-eyed will spot there is an extra pair of holes below the main slidebar holes, which aligns with the holes in the slidebar castings. It will be noted also there is an etched slot in the frame spacer that coincides with the deeper stretcher on the cylinder etch.
Anyway, etch and instructional errors aside, you can see the cylinders are nice tight fit in the fine scale width frames. I assume, given S7 spacers in the kit, the builder must chope the cylinder assembly in half to accommodate the extra. Nothing unusual.
I turned to some calculations to work out how close the model is to the real thing in terms of widths and so on. I'm not good with numbers, so this took a while! I needed to work out the scale factor from the print of the GA I have. Knowing the wheel diameter is 4ft 8.5in, this gave me a print diameter of 44.5mm. Eventually, my brain cell, assisted by the more mathematical brain of Best Beloved, came to the scale factor of 0.742. Multiply known dimensions (converted to millimetres) by the factor to give me millimetres on the model. So, across the outside of the cylinders in this case gave me 60.8mm, and I confirmed this on the brass bits.
So, the cylinders are the correct scale width. How that works on an S7 model is anyone's guess!*
To give me some extra space behind the slidebars, therefore, I think I will split the cylinders and shift them outboard by a half millimetre or so. I will have to make up a wheelset with the crankpins in place, and then fit the cast hornguides and stuff, then juggle with connecting and coupling rods to see if I can squeeze a bit more here and there. I think it is fair to say there will be precious little, if any at all, sideplay allowable for the leading drivers. It looks like a rolling chassis this week is not going to happen after all.
I might need a bit of a lie down before that.
* Quite simply, an S7 builder files back half-etched rebates in the various slots to accommodate the wider frames, keeping the correct scale outer dimension. Obvious, really.
