Heather Kay
Progress is slow. That's my fault, but there are some things you can't rush. I also have this habit of avoiding doing things that are causing me problems, so I've been doing some other bits of the build while the problem bimbles about in the lower memory registers in search of a solution.
I tried using a sprig of fine wire as a hornblock retainer.
It kind of worked, but it would need more than one wire to be efficient. At this point, I decided it would be a good time to fit the frame overlays and get around to fitting the frame spacers ignored by the instructions.
After some more bimbling, I decided what I ought to do next was make up the coupling rods. Instead of actually doing that, I made up the actual valve gear. Don't ask. It just seemed the right thing to do.
Oddly, a relatively relaxing, educational and interesting excursion. For those that like that sort of thing, you'll be glad to learn the slotted link castings allow the gear to be reversed ALTRT. The valve spindles needed quite a bit of careful fettling to get a nice smooth movement, and I am currently unsure of how to fit the return cranks. Another problem to leave to bimble about.
Oh, and I remembered I had some CPL cast crankpins nuts, which included a pair suitable for use behind waggly bits. That saved me a little bit of engineering, at least I hope it has.
Onwards!
Onwards!
