Martin Field
I re-grind worn out out broken Swiss files into scrapers and chisels for plastic and solder excess. Keep em sharp on a small whetstone.
Nice thought.Graham, Heather, Matt, Simon,
Have you tried pipeweld to join Easybuild parts? Just a thought, but I've used it for styrene so know it works there and of course it's suppressed to work with polypipe (PVC). It also takes a while to harden off completely so would give the solvent time to properly 'bite' into the plastic.
Just a thought.
A Kadee installation at the compartment end. It probably doesn't need two bolts, but I'm not glueing the box in place. I drilled the bolt pilot holes 1.4mm which allowed the 10BA bolts to self-tap into the floor. The nuts inside are insurance!
I'm not too keen on the swarf from filing and sanding, though. It gets everywhere!
Not always, the gangways are indeed sprung but on Buckeye stock they take none (of any meaningful force) of the buffing forces, the buckeye coupler does that and with very little movement; hence their requirement fairly early on for passenger stock in an attempt to stop coaches overriding or concertinaing during an accident. The whole purpose of the buckeye is to make the train as rigid as possible and form one long vehicle.Dave,
It's a tricky one, as you know! Prototypically the gangways act as buffers, ........
