Some more work today. The cab this time.
Arm rests (scratchbuilt from styrene)
Cab ventilators (styrene surround and Plano HO etched louvres cut down to size)
Sunshades (scratchbuilt from brass channel and sheet)
Door handles (P&D cast brass)
Both sides of the cab are identical
After looking at one of the earlier 3/4 views of the loco it appeared the Farr air filter box sat a tad too high. I have now corrected this by cutting the box out and lowering it slightly and to me this now looks right.
The white taper plugs in the pilots are styrene rod to fill the unwanted footboard holes. The taper plugs were formed by holding the styrene rod over a flame to soften it and then gently pulling it apart to stretch it.
By the way the cab, body and sill are separate sub assemblies and will be stuck together once the model has been painted.
