Peter Cross
I made a start with the tender bogies. These as per the instructions lock the wheels in place very early in the build. I do not like this I like to be able to remove them.
So following the example of how the Dukedog bogie is assembled I did some modifications, I built the inner frame as a syand alone unit. Be very careful opening up the bush holes or they will wander, they are etched at about 3mm.
A sample of the tab and slots, to my mind better not to have them. It is a pain to fill the gap and not loose the rivet detal cleaning up. Anyway the outer parts of the bogie soldered up nice and square. I added a support each end to carry the nut and inner frames.
The whole lot fitted together well. So much easier when it comes to painting.
I also made the frame for under the tank. This was straight foreward until the fitting of the bogie pads. These are designed to fit flush with the longitudinal frame members, but the cross ways ones are full height so need the centre filing down. easier to do before assembly.
Yes I know I have the frame the wrong way around I was just checking clearences. it is sitting about a millimetre low which is good easy to pack to the correct height.
