Yes, I think a light touch is required! No need to torque the chassis and body together.Interesting.
a pal had terrible issues with a 9F he’d bought, and could not get it to run. I offered to have a play, and see what I could do, and eventually traced the issue to a very stiff boiler/footplate assembly causing a relatively much less stiff chassis to twist when assembled to it. Unfortunately the boiler assembly itself had been built (and subsequently nicely painted & weathered) slightly twisted, so I had to shim the mountings to get it to sit sweetly on the chassis, and not look wrong, but that done, the running was very much improved.
if you make sure your footplate & boiler assembly are true, I don’t think you’ll have any issues with twist.
I've got a broken file which does quite well. What I'm getting a bit fed up with is picking bits of fibreglass pencil out of my fingers. I seem to remember seeing a similar sort of pencil thing , but with steel or brass bristles. Probably imagined it in my crosti-induced delerium!A graver may help for flat surfaces. Or grind a cutting edge of an old file.
Look for Expotools pack of three propelling brushes, each with a different type of fibre.I seem to remember seeing a similar sort of pencil thing , but with steel or brass bristles.
Just ordered a set.Look for Expotools pack of three propelling brushes, each with a different type of fibre.
I tend to use disposable nail-files, which I guess are similar.Sticking strips of abrasive paper to coffee stirrers with double sided tape make a useful tool for sanding in difficult places.
They look interesting Rob, so I've ordered a set. Will see how I get on with them.I find these invaluable, I was pointed at them by a friend in Oz
This image is from Amazon as it's where I got the last lot that I bought.
https://www.amazon.co.uk/Wobekuy-Bristle-Abrasive-Polishing-Accessories/dp/B097NHP7CM/ref=sr_1_6?crid=E9ZTPP602KKD&keywords=rotary+tool+abrasive+spider&qid=1647513534&sprefix=rotary+tool+abrasive+spider,aps,94&sr=8-6
I find that they are even more effective at cleaning up solder if you double them up.
It's a tricky one, but on some of the pictures I've studied there is a change of shadow exactly where you'd expect the angle of the bracket to change. I'm reasonably confident I'm on the right track and have made a slight 'adjustment' with my piercing saw.It seems to be a question of which photos you look at. I've no idea of the provenance of these two poor
photos:
