garethevans1986
meanwhile, back to the thread.......................
Sorry Mike!
Looking forward to seeing the progress of this inspection saloon.
GE
Did you say or have i read somewhere that Easybuild might be doing one soon ?Rob
I think that as regular / rectangular objects are easy to draw as a number of laminates.. or develop a 2D fold-up of a 3D shape... then having the item on the etch is a non-recurring cost to draw with a very low recurring cost as an item within the etched sheet.The 'tell tale' junction box and the little box on the lower right hand side have to be fabricated! again why no casting?
a prolem arose earlier this week in that the Heljan 33 that I recently sold was returned to me as it was not running as it should have been (it ran fine when it was with me, as the video shows) - when I checked it out, the problem was the Heljan gearsets - what else!
I contacted Howes of Oxford who put a replacement set in the post which arrived the following day, fitted them and ran the chassis (DCC powered) no problem. However, when I refitted the body, and ran it up, there was a grinding noise coming from the repaired bogie area, I removed the body and the marker pen markings that I had put on the flywheel of the offending bogie had almost been rubbed off so checking at the underside of the body I saw that there were abrasion mark to the underside of the fan motor housing - somehow, the body seems to have become lower, causing the 'coming together' does anybody have any thoughts? I am thinking that a 6BA washer glued to the top of the casting on the chassis might do the trick, we'll see.
regards
Just seeing this Mike, you will have to do the buffer centers, you may need to do the light switch on the end. I used a WEP rocking unit from the spares box, and you will need to strengthen the steps as they last about 2 seconds in use. If you have both use the JLTRT body on the WEP underframeAs stated on Simon C's thread I have made a start on a WEP Fruit D - rivets punched on one end, using my new GW rivetter, very pleased with the results, but having read the Guv's comments regarding strapping, I will wait with bated breath for his responses before going too far down the line.
I also bought the NQLTRT version at Telford, I am aware of the buffer centres problem and the general underframeis there anything else that I should be prepared to 'upgrade'?
If you have both use the JLTRT body on the WEP underframe![]()
Hi Mike,
Very annoying trying to find the issue when you're not really sure what you're looking for. If you want I can take the body off my 33 and take some pics for you if you want a comparison?
Tom
