Mick,
Anyway, back on topic , I take your point with the roof ribs; have you got pictures of the locos under construction that might help? I was thinking about this again this evening and dug out a couple of pictures of 10201 under construction, which showed an almost aircraft-like construction, with hoops and stringers. However I've also managed to baffle myself completely with the arrangement of the roof panels - a clear roof shot would help me enormously.
Good luck with the Carter drawings - I recognise their odd (mostly minor) weak points having re-drafted a set of Class 50 drawings some years ago. But they remain very useful and much better, in general, than anything else available.
Steph, these are about the best roof shots I've found on the web
http://www.flickr.com/photos/brianews/5863363870/sizes/l/in/set-72157627028690682/
http://www.flickr.com/photos/brianews/5863364180/sizes/l/in/set-72157627028690682/
they clearly show the dents and dings the roof panels take, of further note are the panel weather seals, they will be a chore if I am to replicate the rounded profile correctly. I do have some construction shots in a book, will fire up the scanner some time today and scan them in, I presume it'll be alright to post them here so long as credit is given to original author?.
Class 50, that is one on the to do list, I havent gone over the drawings yet with respect to the 1:1 loco, so don't/didn't know there were issues with his Class 50 drawing, having said that, I've seen lots written on the minor faults from the Carter drawings, so it kind of follows that most if not all will have errors here and there. Do you per chance have the factory roof radii, if it follows my hunch of EE using the same profile then they should be 65 & 1/16" for the main roof and 22 & 9/16" for the cant rail/grill part.
Kindest
