This is the bit you're going to either love or hate!
So, depending upon which manufacturer's kit you have it's possible that 'features' will need to be removed from the floor and anyway you choose to do it the fixings for the brackets need sorting. There's a key dimension here in the positioning of the two outer drive brackets to allow for clearances on the universal joints. The motor and central drive bracket can go between, as you choose:
So returning to a point that I think Martin (Pugsley) raised, I just thought I'd quickly show how the motor can be hidden by the underframe gubbins if it's carefully positioned. I think I've correctly interpreted the Easybuild instructions, but based upon recent experience (and the breakneck pace, more of which later) I can't count on it:
With all the positions worked out the rib details where the motor sits have been removed (chisel followed by scraping with a curved scalpel) then the holes were drilled and tapped:
And proceeding at a frightening pace the drive assembled and bogies fitted:
En route the process has not been without casualties. Along with the scalpel cut to the pad of a finger (yes it does smart a bit when typing) my patience has nearly deserted me. Y'see I got to this point and found there was a definite tight spot and a lot of motor noise; assuming the worst I stripped the drive shafts again and aligned them properly (slacken off the screws a touch, wiggle parts to free running positions, re-tighten) with no joy. Ran the motor up again to a lot of noise, heat from the motor and the sight of a bearing dropping out of the centre drive bracket. I'd missed a bearing with the Loctite, so that was sorted. At this point I thought I'd better run up the motor to bed it in and hopefully reduce the noise. No joy; off the chassis the motor was leaping around the workbench. Not entirely sure what the problem is, I suspect a bent shaft. Whatever; it's knackered so I'll have to get a new one for the full build and means I haven't been able to do any sensible testing. Apart from...:
1. Grabbing a 6' radius template I locked the bogies off at the desired positions for a 6' radius curve and the drive works very well; it will comfortably go tighter. The dimensions I worked out are accurate. So that's good. I'll be happy to provide that info to anyone who's going to give one of these drives a whirl.
2. The inclination of the drive shafts isn't as bad as I feared. I knew the sketches were done to 'worst case' dimensions and it's pleasing it's worked out. Also nice to know there's a little bit of a safety net and that the floor being a mm or so above or below the optimum doesn't seem to affect performance.
There are some pointers to consider before installation;
Test the motor and run it in before installation (Grr!) infuriating because I
always do it; except this once..!
All manufacturers should test build their products (and ideas) before inflicting them on modellers, sometimes you find the damndest things!
The extensions to the motor drive using aluminium tube and neoprene tube works well.
The etched parts also work fine - providing they're used as intended and the bearings retained with Loctite.
The floor needs to be stiffer than a 'raw' styrene extrusion; accuracy built in during assembly of the drive is instantly lost as soon as the chassis is placed on its wheels. I'll be running a 1/8" square brass section inside the frame rails to solve that problem on this one and I bet a Westdale frame will work very well.
That's it. I'm pretty happy with the result having learnt a lot in a very short time. I now know I've got a couple of jobs to do in order to build up the rest of the Bubble. But (and the major qualifier) is that as a proof of concept it has worked well.
Any takers?
