Goodness - six months since I last posted. There's been a good bit going on...
For a start I think I've given up on the T1; although it looks as thought it could be made up quite sensibly into a T1 it just doesn't have the necessary finesse or detail for me to feel it was worth giving it a set of inside motion. So it'll disappear via Ebay or a Bring and Buy or somesuch. I'll have to think about another suitable loco to use to test the 'RQN' gearbox.
Ah yes, gearboxes, I knew there was a reason for me to update this thread. Things have been moving along and the diesel drive 'boxes have now been test built at Mk2 status. It's taken a while to get this far, but it's worth it; set up is now very much simpler than it used to be and it just goes to show that I do listen to feedback I receive. Incidentally, existing owners of the original diesel drive boxes can upgrade for a very advantageous price if you like what you see, 'cos I'm good like that. Just drop me an email or PM if you read this...
So this is what the 'Power 13:1' version now looks like (on the right), with a Mk1 for comparison. Changes include a slightly stronger frame that's a full fold-up rather than two-part. I've also completely abandoned use of the additional head bearing; most of the feedback I got was that this wasn't necessary. Motor fixings now use a motor twist to fine-tune the gear mesh, although that has meant that only 12mm and 15mm M2 fixings are now provided. Yes, the Mk2 has been blackened and no, it didn't go swimmingly, although it can now be done without risking the bearings:
The 'Remote 13:1' has been subject to more significant changes. One issue we've had has been that the gear mesh centre isn't constant; changes in shaft dimensions, reaming of the bearing seatings and the gears themselves all affect the ability of the gears to mesh absolutely perfectly. So the solution was to try and find a way to separate the gearbox into components such that the mesh can be fine tuned. A bit of thinking resulted in what you see here - even using the same screwdriver you need to build the 'Power' version; how's that for forward-thinking? Again the Mk1 is on the left the Mk2, with shameful metal blackening, on the right:
Incidentally, all my gearboxes are now provided with the frets reamed to take the bearings so you can just fold 'em up with some care, solder, clean and assemble, an M2 tap being the only piece of specialised equipment necessary to assemble the 'Remote' version.
The first set of these Mk2 gearboxes are destined to go in my MMP 56, which made me think a little about other desirable traits for diesel locos, resulting in this etch:
This includes a couple of cosmetic parts; such as the different cab backs for each end of the loco, together with glazing seal, hinges and lock. There's also a fold-up for the bogie's external compensation beam. But the main focus of the fret is a number of beams, spring clips, jigs and a new bolster to give CSB-style primary and secondary suspension. I'm intending to do a few more bits and pieces for Class 56s, including multi-depth etched grillework. Just guilding the lily really; I still think it's a fab kit.
![IMG_8925v1.jpg IMG_8925v1.jpg](https://www.westernthunder.co.uk/data/attachments/43/43382-01a0119a737ecdfa6713dd1a85c2ebb2.jpg)
![IMG_8924v1.jpg IMG_8924v1.jpg](https://www.westernthunder.co.uk/data/attachments/43/43381-14e65f67050564ad34600e35ac0da23d.jpg)
![IMG_8927v1.jpg IMG_8927v1.jpg](https://www.westernthunder.co.uk/data/attachments/43/43383-d22508ee8b8c471e791e49efaac954ca.jpg)
