Perhaps i should have posted this before the picture of the semi finished tank but here is tank number two on the way and i can explain a bit about it,
Basically the tank is formed of two ends and three lengths which have about 120 degrees of the circle each.
I had hoped to substitute these with a piece of pipe but measuring the ends showed the diameter to be 60.7mm which does not convert into a meaningful imperial measurement either, maybe you 7mm chaps will be luckier.
To add to the joy these three parts are attached to a thick sprue, have heavy mould lines along the edges and industrial amounts of flash to carve away, new moulds please
You start by gluing the three curved sides together with Mek-Pak or similar, i followed this by using araldite on the inside and also added a piece of steel rod to add some weight. After this attach the ends with Mek-Pak.
The holes for the detail on the top are rather usefully indented inside so run a pilot hole through them before gluing up the sides. What happened with the first tank is i applied filler along the various seams which when dry sand down until you are happy that you have lost the joints, repeat as necessary then coat with a grey primer.
In my case the primer screamed back at me "should have gone to spec savers" and it took another three attempts until i was happy with it. Its not all doom as the brass castings are lovely and are better than anything you will find on a rtr model.
I am hoping to get all four tanks ready before i actually need them as i reckon with it being such a complex kit there is a danger, to me certainly, of trying to rush and buggering it all up at the 11th hour. Hope this makes sense, cheers to all, Rob
