michael mott
Pressing on with the van I drilled the wheels for the bolts.
I decided to just use some .020" wire and snipped them off and flooded them with some black primer.
The brake hangers are fixed to the shoes with some turned .020" pins
Spent a bit of tome today turning up some .020" rivets for the step brackets to replace the wire keepers.
And machined up some fake 1.2mm bolt pins the shaft is .020" to hold the axle-boxes from falling out of the W Irons They look better in real life than the photo for some poor photography reason. I used the pin vice method of filing up a turned pin 3 stokes of a #8 file for each side, I marked the nut of the pin vice with the numbers 1 to 6 because it is such a repetitive task and I forgot that I had already filed one of the sides and made a couple of lop sided nuts that I needed to keep better track rather than counting to 6 for the turns. Just made it easier while I wait for the Hex draw plate to arrive. it goes from 3mm to 1 mm so I am excited about it.
Michael
Michael
