Jordan Leeds
Member
It's great to see a model of no 5 I have just placed an order with a very nice chap for etches for no 5 myself and am working towards a small 0 gauge layout based on Wantage Town
It's still fiddly, but also very therapeutic for me.Brilliant Mike just wow! 7mm must be easier!
Which is one of reasons I persevere with the 7mm models despite having the option to go and play with my G-scale models.
Hi PeterAgree with Ade.
What a simply wonderful model!
I sometimes despair at my 4mm version....
Unfortunately the whole assembly is firmly soldered in place (next time use nuts and bolts), and unsoldering it was not an option. I got a bit down about it and walked away from it for a few months.
So stick with it but maybe if it's getting to you a bit then have a back-up project. Mine was the Terrier-based crane locomotive which I've posted build details elsewhere on WT. Can I ask where you got the buffer housings from? They look very much like the GCR Sacre ones I need for a 7mm scratch-built 12AT.
Thank you - I need to contact David White at Slaters anyway.
Thank youI have a feeling they are Slaters GWR Collett (tapered) ref 7907, but I'm sure David White will confirm one way or the other.
Anyway, I decided to try a High Level gearbox. To be honest it was make or break. If this didn't work I was going to throw in the towel.
If I can figure out how to post a video I'll do so. I'm the meantime here's a few pictures of the High Level gearbox.
Those are just what I needed. Thank you so much.Hi Mike. I like that gearbox arrangement. Very tidy.
These pictures were taken some time in the 70s, at Didcot.
Hope they are of use.
