Podartist79
Thank you.Saw this loco only a fortnight ago. Currently blue, in service on the NYMR.
I remember the ‘white marks’ represented on the bogies. Never knew the cause. But that is exactly the appearance.
Amazing work.
Amazing work.
Hi Neil , so if i have this method correct you apply the powders as per normal then use the pigment fixer to seal it in .Thank you as ever Steve, very kind.
I don’t use the apply and wipe off method on diesel roofs (or coaches and vans).
I actually used a pre-shading coat through the airbrush in a dark grey-black around seams, joints and hatches.
I then, using light layers of roof dirt (a mix, not the full ‘roof dirt’ colour as supplied by various manufacturers) through the airbrush, cover the whole roof but allowing the pre-shading to show through.
The next step was to add various weathering powder runs, that I fixed in place using the AK Pigment Fixer (airbrush) followed by further coats, thinly, of the roof dirt colour(s) again, using AK random pattern masks to get the small and random blotches etc.
Hope that helps.
Neil.
Thanks for that Neil . I inherited a bottle of the pigment fixer after a friend passed away and have wondered what its use was .Hi Paul,
I think you can use the pigment fixer both ways round.
In the first instance as a fixing agent after you’ve applied weathering powders.
In the second instance, you could spray/apply the fluid to an un weathered item, the powders would then adhere to it. It may require a further coat over that though?
The virtue it appears to have to me, is it doesn’t affect the weathering powder colour after application, or overly tone it down.
Hope that’s helpful.
Sorry to hear of your friends passing Paul.Thanks for that Neil . I inherited a bottle of the pigment fixer after a friend passed away and have wondered what its use was .
Hi Neil, could you advise which pigment fixer you use please. I've used something previously but it really changed the colour of the model, spoiling the finished effect. Many thanks.Hi Paul,
I use the AK Interactive pigment fixer Chris.Hi Neil, could you advise which pigment fixer you use please. I've used something previously but it really changed the colour of the model, spoiling the finished effect. Many thanks.
Thanks NeilI use the AK Interactive pigment fixer Chris.
Thanks Steve.Love that crane. The coal in the bunker is superb!
You definitely shouldn’t give up Alan (I know you’re joking).I almost feel like giving up. But not really. Smashing work.
Hi Steve,The Bullied is fantastic, less is definitely more!
Can I ask about the 47 Neil, how did you treat the body sides, they look clean but not "out of the box" clean, if that makes sense?
Thank you Neil, it sounds like the old adage, less is more, which is very effective! I've re painted a couple of locos and after decals, etc I matt varnished them, that has made working paint around difficult.Hi Steve,
Please forgive my tardy response.
It’s essentially much the same methods I use throughout when weathering loco bodies.
I apply a mix of grey-browns in oils, to the body sides, working it in around grills and raised detail.
I then wipe most of that off - in a vertical motion - with a soft cloth.
The next step I use, particularly with a pretty clean loco, is some very big soft flat brushes to blend the previous ‘wiping down’. Again I use these mainly in a downward motion.
I finally touch up/blend the lower half of the body sides using another thin dirt mix through the airbrush.
Hope that’s useful.
Neil.
