Some more fiddling but rest assured Rome hasn't burnt down.
This time with the radiator parts. I made up pieces supplied in the PRMRP kit (right) but these looked too chunky and there is no daylight between the structural supports and the radiator grille behind. Added to which the casing is a sloppy fit in the hole in the body side created for the radiator.
So I decided to start making my own from styrene (left) which also allows daylight behind the structural supports. Only one side has been completed so far.
The external radiator grilles, ah ha. the chain link fencing (left) is supplied with the aforesaid detail kit which is rather crude. I searched around my spares box and found some finer etched grille (right). Although finer it's not fine enough but will have to do until I can find some. When looking at prototype photographs the radiator grille almost appears invisible.
Here is the fine grille over the radiator.
One item I'm finding irksome after painting are the body side louvres (louvers). After
much little deliberation my conclusion is that they are totally incorrect- the curved corners should at the top, there should only be five and not six in a group and are too wide anyway at a scale 12'' instead of 6''.
I would have sorted these out today but I cannot find my Archer Decals Louver sheet. It's almost as if the Bermuda Triangle in a corner of the workshop
This selective enlargement of a Jon Biglowe (copyright owner) photograph from t'interweb shows the louvres.
It also reveals the drawing I used for the structural supports in the Modern Locomotives Illustrated Class 33 book is wrong. I have the vertical support too far to the front and should have looked a a photograph first
. Oh well. Fortunately it's easy to rectify
