Hayfields 7mm 3D Printed Turnouts
Hayfield1
I am sorry for a long delay in adding to this thread, the reasons are :-
1 I have been finishing off 4 kit built locos
2 Waiting for the latest Templot release
3 Waiting for plug track parts
4 The Scale7 Albury meet is getting nearer, where I will be demonstrating 7mm scale 3D COT and Plug track
Well the locos have nearly been taken as far as they can be until the weather has turned both dryer and warmer
Secondly the Templot release has arrived, I have cut the ply for my 7mm COT track test plank
Finally waiting for a filament dryer which apparently will improve the performance of my printing
Also I have been having a chat with a couple of folk, Terry who will be printing the additional parts I require for the plug track kit, Terry also asked me for a couple of prints of FDM bases, both COT and plug, and another retailer who is interested in the concept of 3D track printing for his next personnel project
So the COT/Plug track projects are back on and after the priority items I will have a go at printing a 4mm scale COT track turnout
Hayfield1
Just been using up some old filament, tried the new style common crossing design (which is mainly aimed at 4mm scale) in that the check rail chairs as well as the common crossing has stub chairs to aid rail fitting
A B6 curved (4.4m radius) COT turnout to 0MF gauge (31.5mm gauge). The filament has been out in the open for 2+ months, so not in prime condition
To use up filament just printing off some chairs (note a bit of stringing, probably due to exposure to moisture)
Test print in a few ways, using Sunlu PLA+ filament and Filament dryer (drying out the remnants of the old reel which I will test once dry
A few more jobs to complete prior to testing a 4mm COT track turnout
Hayfield1
Following on from my plug track Templot build I received the additional parts I required plus a few more bits
The first and most interesting part is the production version on 3mm ply, I did receive a few chairs which Terry modified but not enough to use on this track base.
Now in the Templot club there has been quite a bit of opinions on Resin and FDM printed chairs, what has happened recently is in using a certain brand of filament and keeping it dry in a filament dryer the print quality is better. The truth is the gap between FDM and resin prints has really closed up, to an extent you need to get very close up to notice the difference, to me the advantage is FDM printing is easier, far less messy and overall quicker
I am sorry for the quality of the photos, plus they are four times their real life size, when compared to ABS chairs there is little or no difference
My bad computing skills, S1J to the left S1's in between and for some strange reason a PL4 chair to the right
Slide, S1 & L1 chairs, this photo seems to catch the crispness of the printing
Slide chairs PL1 to 4, they are both sided and handed, somehow I have disabled the raft function, I use more glue but save on Filament
Likewise the common crossing and check rail chairs are also position sensitive
Now I am experimenting to see how viable FDM chairs are in turnout building, the known problem areas are the PL3 & PL4 chairs and the wing rail chairs. These may well have to be loose jaw type or Terrys half chair versions
Certainly the latest developments has for me made life far more easier, I cannot do any design or programming skills to the game, but I can try and bring a bit of the end user/track builder experience to the project.
I am now testing the filament brand I have been using from the start, namely Esun by printing an EM gauge COT B6 turnout. The price difference is negligible especially as the filament is probably the cheapest element in the whole process. I think the cost of filament is 10p for 20 plug chairs. However that's not counting the cost of getting here, but its been hours of pleasure, fun and frustration.
Worth the journey, certainly
Do look at what Terry is doing at Kosmik
Terry will be demonstrating at this years Risex this coming weekend
And James Walters has been very busy
Hayfield1
I left the Kosmik turnout build as I was missing some of the revised parts which are in the production kits and are a great improvement, Terry has to a certain kept to using whole chairs rather than chairs with loose jaws, by redesigning some chairs into half chairs.
I was sent several revised items, the first 3 revised half chairs rather than loose jaw chairs, also for show only a set of loose jaw check rail chairs
These are three sets of half chairs designed to make it easier to fit chairs which hold 2 rails
Top left PL1 to PL4
Top Right check rail chairs
Bottom Vee chairs
These are the additional switch chairs, left to right PL1, PL2, Pl3 & PL4
PL1 & PL2 only have the stock rail through the chair as the switch rail slides on the slide plates so are full chair, PL3 & PL4 are half chairs to make construction much easier
347.jpegr
These are the check rail chairs, top row go on the stock rail, bottom row on the check rail, the two end chairs are hander R (right) L (left) as they go on the flared end
For information only this is a set of loose jaw check rail chairs. The stock rail is laid on the chair and the jaws are pushed in, likewise the check rail is laid in and the other jaws are pushed in
Back to the build I want to change the PL1 to PL4 chairs as they are so much easier to fit as half chairs rather than sliding the stock and switch rail through one chair
Sorry about the focus in the foreground, Half chairs PL4, & PL3 are slid on the stock rail along with chairs PL2 & PL3. the stock rail can be easily fitted into position
Now I slid on the two remaining Half chairs PL4 & PL3 and again the switch rail is easily fitted
I must say a very easy solution and probably much easier to print than loose jaw chairs and jaws. Certainly an easier solution for the novice builder
Hayfield1
Carrying on with the build, the stock rail was cut to length, preformed to shape and the standard S1 chairs threaded on
These are the set of half check rail chairs, the top set of half chairs are for the stock rail, the bottom half of the chairs are for the check rail, the two end chairs are end sensitive. CCR & CCL must go in the correct position. Looking from the outside of the stock into the center CCL is on your left side and CCR is on your right side as they fit over the check rail flanges rail into the center.
Looking at the photo above, the upper chairs fit the stock rail the lower set of chairs fit on to the check rail
You can see here the raft has been turned around 180 degrees, the stock rail CCL has been fitted on to the stock rail
I have now fitted all 3 center check chair outers on to the stock rail
All 5 of the outer check chairs have been fitted to the stock rail. out of sight I have fitted the rest of the chairs and the curved stock rail now fits nicely into the fret
This view shows the switch chairs PL1 to PL4 in-between the last slide chair and a L1 chair, PL3 & 4 are half chairs. The other half chairs will go on the switch rail once made
A quick overall view of the turnout with one check rail and a switch rail yet to be made and fitted
I must say these revised half chairs made fitting the stock rail very easy
Hayfield1
Both for a domestic test track for me to use with my loco kit building I thought a lightweight 3D demonstrating board would be a good investment
A base board from a 3mm thick sheet of ply 48" x 9" has been built. You can see I have used Copydex as an impact adhesive to lay some 3mm High density foam
A simple A5 turnout with about 16" run offs at both ends. the etched primer is nearly white
The single track has the base sleepers and chairs painted but the masking tape is still on the rails until I have touched up the painting
Next up will be fitting the track to the track bed and ballasting, simply to show what 3D printed track looks like in use, and of course see it working.
I will have it with me at the Scale 7 meet at Albury and also hopefully at GOGA show at Kempton Park
Hayfield1
367.jpeg Masking tape has been taken off and rail tops cleaned
Track positioned where it goes, I plan to fit the track one section at a time
Scrap test pieces do come in handy, neat Copydex painted on to the track bed, track placed on it, then ballast poured over, clearly needs another 1mm covering of ballast. Still quite a change from bare PLA+ filament
Hayfield1
372.jpeg Nearly 2 weeks have passed since my last update on the COT track demonstration board, All tracks have been laid and ballasted. Droppers fitted prior to track laying. The wires were fed through holes once the base layer of ballast dried
374.jpeg The track was wired up, mains power is fed in via a 3.5mm jack plug. Controllers via a 5 pin DIN plug
378.jpeg A bit Heath Robinson, but a GEM lever frame was altered to both work the points and a microswitch. I now need to design and build a lever frame cabin to both hide and protect it.
Next up to ballast the track properly.
As for the turnout, it works perfectly
Hayfield1
381.jpeg Ballasting the track has commenced using 7mm Green Scene ballast
382.jpeg Not bad for someone who is well out of practice in ballasting.
Now need to explore weathering
383.jpeg I am very pleased the overscale look of the tiebar has reduced. The lash up method of attaching it to the lever frame is acceptable on a test track. Just needs refining tor a layout use
So far so good all works OK
Not generally known perhaps but they do a self-adhesive variant, which is excellent and a great time saver being much easier to lay than trying to stick down with glue. Costs a bit more but well worth it.
Thank you, Stephen.
Much appreciated.
However, I’d worry that in time the adhesive would give up the ghost, so I’d probably employ belt n braces by supplementing with Copydex, of which I have a copious amount.
Jon
Hayfield1
Well done, John.
Good job!
May I ask where you sourced your high density foam?
Jon
C&L Finescale, I am surprised others do not supply it, I forgot to use the 5mm thick sheet I have and only used 3mm. At very low speeds its quiet, noise picks up as the speed increases. Still the board design is basically a drum.
Hayfield1
Thank you, Stephen.
Much appreciated.
Jon
Jon
Copydex/latex glue in my opinion is very underrated and perhaps misunderstood.
My wife was a professional artist in the packaging industry, and it was her that introduced me to Copydex being used as an impact glue. Not very popular now and not as easy as other glues to find, using neat has other properties so a very useful glue
She also used Cow Gum, a name from the past I cannot remember seeing for ages
Jon
Most grateful, John, for both of your useful replies. Food for thought indeed, and reassuring to hear of the reliability of Copydex.
I’m wondering whether the 5mm you refer to might have proved a better acoustic barrier, although Zotefoam as kindly shared by Paul (@Paul Cram ) sounds interesting ?
As I say, worth considering.
Thanks again.
Jon
John_B
I see it says on the bottle it's a "new improved formulation". Is this newspeak for "it's nowhere near as good as the old formulation, but our bank accounts are more important than whether it works for you"? I've ordered some, on eBay, anyway, as I've been meaning to try it for years.
