A huge hole was required for the chimney to fit into, unlike other chimneys that sit on the smokebox this casting sits in the smokebox. Creating the hole took some time and I found it easy to wander off the centre line and found myself out by about 1.5m. Fortunately there is a half etch chimney base to solder over the hole masking any errors.
apologies for the contrast, and now with the chimney in place.
With this job finished my attention turned to the deflectors and outside steampipes. What looked like an easy job has in fact turned out to be quite fiddly and time consuming. The large whitemetal castings had to be ruthlessly filed down to get the deflectors to stand vertical. In addition the smokebox door has been detailed and fitted.
While steampipes and smokebox door were curing a start was made on the tender. The inner frame was constructed on the chassis jig and the brake gear assembled. The opportunity was also taken at this stage to put in tender pick-ups. Construction of the tender is quite straightforward and although I have built two other 4000 gallon tenders of this type there are some subtle differences principally concerning the location of the tool and crew cupboards.
There is a lot of cleaning up yet to be done and this will be left until most of the construction has been completed.
So tonight the locomotive is beginning to take shape. The deflectors have not been finally fitted as each has three ties onto the handrail and they still have to be made. Hopefully by the end of the week the reverser rod and injectors will also be in place.
Lastly thanks to Peter for your very kind words.
