Long time no Update
Looks like I had a clean up of my Photobucket account too; some of my pics are no longer here.
Ah well, here's a bit more US track mischief from Muggins...
First a bit of back-story. Over the past few years I had been building a combined HO/OO layout up in my loft, to run both my US-outline HO stuff, & my lad's OO stock on. There's an old Thread about it here somewhere. As he's grown, he's moved to N Scale, and I wanted to concentrate on O; trying to model in two scales meant I accomplished less in either. So once all the HO & OO was sold off, up came all the track. This O scale layout is built on the same boards, and you can see some of the mortal remains of the HO/OO in some of the following pictures.
Overall size is 17ft by 8ft. Curves are tight of necessity (more of which in a bit), and I admit I would not contemplate a British O layout in this space, due to problems with scale couplers & buffer locking.
But we're not modelling British trains here, are we...??
The part I call the Industrial Branch is laid with Code 100 rail (salvaged from the HO/OO layout!). the Main line (which will basically be a roundy-roundy oval) will be Code 125.
First a look down the Industrial branch. Track uses Peco track spikes, thin card tie plates, and coffee stirrers for ties. The Main line will pass to the left, where all the clutter is now
It's more or less just a long Inglenook; just two turnouts and 3 spurs. First spur will have a Chemicals Distributor and Food Processors, the further spurs (below) will be a Team Track & Distribution Warehouse on the right.
Mmmm.... rickety track....
The turnouts are all #6 (apart from the curved one), hand-built over printed FastTracks plans, soldered to a 'skeleton' of a few copper-clad ties for strength. The two on the Branch have my home-made "Self Guarding" Frogs. I have NOT forgotten to fit wing or guard rails!!!
Curves, as I said, are tight - about 3ft radius or so. From above, they look very silly...
... but the layout is mounted quite high up, so the natural view is more-or-less at eye level, and the view then isn't so bad.
The abandoned Elevator in the background is HO scale; an experiment with perspective modelling.
The branch curves around and meets the Main. You'll really have to use your imaginations here - the main will also have a siding (passing loop in English) to the left here, so trains can be interchanged. It's a simple arrangement, but in America, you don't
need complex track plans to make for interesting and realistic operations...
In the foreground, the start of laying the Main itself can be seen. This track will look a lot neater than the branch, to further emphasise the difference!
The turnout here is Code 125, and uses Right-O-Way parts.
Cast Frog and Guard rails (extra bolts, & tie plates from Grandt Line)
Cast switch rails and Brace Plates (Caboose Industries ground throw - the N Scale version!!)
Cast Transition Joint Bars for Code 100 to Code 125 rail join, from American Switch & Signal
The one turnout for the siding off the main has to be a curved one. I made it off a blown-up copy of an HO switch plan, as such tight radius (4ft outer, 3ft inner) plans aren't available in O scale! The frog is another home-made concoction, this time representing a Rail Bound (manganese insert) Frog. I used a few more copper-clad ties than usual on this turnout to make sure it stays in shape!
So, there you go... that's the misguided nonsense I've been up to for the last few months, hopefully guaranteed to give serious track laying enthusiasts sleepless nights
Hope you like it, anyway.
