Mike Trice
The 2.6mm drills have worked a treat fitting the Peco (or should that be PECO) bearings. Here you can see the very useful hand drill I use purchased many years ago from SM Tools in Leather Lane. I note that there are similar still available on Amazon:
Depth was judged by eye and keep trial assembling the bogies to test end slop. The next dilemma I faced was whether to paint the bogie parts before assembly, not idea when gluing. In the end I did spray them first masking off various glueing areas.
It is a real juggling exercise putting the bearings in then gluing and assembling. Fortunately I used Araldite Original which give plenty of work time. The first assembly was held together with masking tape but on the second bogie I had difficulty holding the sideframes square so opted for a couple of engineer's squares:
Did I do right painting the castings first? Probably not and they could do with some minor touching in.
Meanwhile the bogie mounts were Araldited to the floor with the screw heads also Araldited so they do not turn. I did have to countersink the recesses a little for them to sit flat:
