Healey Mills
Some days it's one step forward, two steps back!!!
Whilst I was sat (having a cuppa) and about to embark on weathering 40060 I made a very sobering observation. The masking of the yellow on one of the sides of No 1 end was not correct, the yellow/ blue interface that should be vertical on the nose sides wasn't. Grrrrr!!! I have no idea how I had got so far along the build without noticing this before, but I just could not let that pass, so I set about correcting said c*ck-up.
Before:
After a little masking and banger blue corrective paint:
I'm going to let this dry and then get some very fine wet'n'dry to remove the lip that was obviously created by my masking on the spraying, once flattened just brush a bit of varnish on. Hopefully this will rectify the fault - not the end of the world, but nevertheless annoying, once weathered I think it will look ok.
At least I have learned a new trick though..... when adding the masking tape put the loco down on a flat surface, with a steel ruler placed on it's end (or set a square) on the table top you can check the vertical. Don't know why I didn't think of doing that before rather than doing everything by eye!!
Lee
Before:
Lee
