Ye gods! Over a year since I last had the courage to look at this thing! Still, I have girded loins, pulled up bootstraps, and forced myself to shift the RMB carcass to the front of the bench. It is time to get this thing finished.
That roof. While I've not been working on the actual model, it's never been far from my brain cell. I've worried over the various schemes, and worried over the order they have to be done in, and I
think there is a way forward. I'm also hoping the faint glimmer at the end of the tunnel is not an approaching train!
Here I am assessing the damage of neglect. Nothing too serious, just a few bits falling off where insufficient adhesive was used. The detritus between outer body and inner body is destined to be fitted into the shell once the roof has been successfully attached. If that bit works, we are all fine and dandy - ish.
Right, struts in place. I've gone with the brasswork at this stage. If the magnets prove too powerful, I have a fallback plan of a sacrificial biscuit tin. Signs are the brass will keep the magnets sufficiently apart to make roof removal relatively painless, but strong enough to hold the curve down to the body.
One of the problems I had been wrestling with was the fact the interior has to be installed before the body struts went in. In an ideal world I would have painted the exterior, fitted the interior, glazed, and popped the roof on - as the designer intended. As it is, being inept, I've had to fit the partially constructed interior, with the intention of the remaining pieces going in after the roof attachment has been shown to successful. I hope to use thin plastic material in the window apertures to mask the interior for livery paintwork, swapping out for the proper glazing material later on.
I have also given some thought to resurrecting tabs to attach the inner ends to the roof. Anythin helping the roof sit down will be welcome, so that's my plan for this afternoon.
