Heather Kay
You may recall I had been baulked by some issues around the roof. I let the model sit at the back of the workbench while I got on with other builds. I needed to formulate a strategy, and leaving things alone was the first step.
At the end of last week I decided it was time to pick up where I had left off. I reviewed the relevant section of the instructions, and set off.
The insides of the ends, the bits with the bolts which go through the floor into the chassis, are designed to be fitted to the ends of the roof itself. The bolts help align things, and then pull the roof down onto the body. Well, that's the plan.
The top of the body sides has etched tabs. These fit into slots in the roof gutter assembly. The roof has tabs which slide inside the body, keeping it all in alignment when the roof is fitted.
So, first task today was to fit the inner ends to the roof.
I tack-soldered the central and outer tags to the roof, aligned as best I could and as square as possible for one end. I then test-fitted. This led me to decide that the inner end needed a pass or two with a file down each side and to round off the bottom corners, just to allow a smoother fit.
It only needed the merest pass of the file, and the end slipped neatly down behind the outer end.
Here I am checking fit and making sure things fit snugly, complete with glittery brass nail polish from the filing. I repeated this procedure with the other end.
Both inner ends were tacked in place, in what I think is the correct position slightly rebated from the end of the roof itself. More test fitting. This might just work...
Things still didn't quite fit. Bearing in mind a full interior is yet to be fitted, I wanted to be sure the roof would slip into place without undue stressing of the body - which will probably be painted inside and out by the time of final fitting. At least, that's the plan. I opened out the bolt holes to let the bolts slide in without excessive fiddling about in and through windows that won't let me have access later.
Now things seem to be going my way. Except one gangway had come loose, and the window frame overlays had decided to part company. Now seemed a good time to remove them carefully and clean things up. With hindsight, the end and gangway details should be left until the bodywork and roof fettling is mostly done, rather than done before the ends are fitted. Anyway… time to try fitting the roof again.
Well, the ends seem to fit okay, and with a little persuasion I could get the sides to line up with the roof slots. How I would do that with the windows fitted - and the paintwork done - is a worry. The roof, during fitting the gutter details, acquired a subtle bow, but enough to give me some grief. Perhaps fitting the interior will help hold the sides in register?
Anyway, feeling the sides could be dealt with later, I checked over the ends.
Okay, that's not good. The roof is supposed to overhang the ends. I spent some time fiddling and fettling to see if the overhang could be created. Something has gone wrong somewhere earlier in the build, and I fear it involves removing the ends of the body and starting over. I'm not sure if it's the bends for the sides, or whether construction sequence needs the ends to be fitted inside the bodysides. Either way, right now, I'm looking at deconstruction rather than construction.
As I type, the model is once again sitting on its length of track at the back of the workbench. I was hoping to get on with the bodywork and start the interiors, but it looks like I need to leave things alone before I break it good and proper.
