spikey faz
Do you know what sort of capacity? I'm thinking a ton?Greg Edwards of Datasheets provided the drawings and Ian Dunn wrote the words for Goods Wagons of NSW. The drawings in the book are available in 7mm scale from Datasheets, as linked to by Mike above. There are some oddities in the book, one being the sheep van section where Ian wonders where the design of the first sheep van came from - it was an exact copy of the LNWR double deck van down to the last detail as published in DK Clark in 1855, designed by HH Henson. The drawing in the NSW book is longer than it should be to be accurate.
The NSW Terrier conversions were different to most crane tanks as the crane was low capacity, just enough to lift the coal tubs to coal locos as the were intended to. Presumably they were quick acting to speed the process up.
