I have put the Barclay conversion on the back burner. There's no point in starting a new project whilst unfinished ones are stashed away in drawers.
One such project has been resting for a couple of years. A friend bought a second hand kit-built BR Class 02 that was built from a DJH whitemetal kit. It was a really poor runner and the paint job wasn't much better, so he gave it to me to sort it out for him. Around the same time I bought an unbuilt but incomplete whitemetal DJH 02 kit from ebay. It was very cheap, with no other bidders. I suppose not many people are interested in something that they can't finish with what's in the box.
I had the idea of converting the kits into Yorkshire Engine Co. 220HP diesel-electrics. The first stage was to buy an Oxford RTR Janus and rob the engine casings from it. I took the entire body off and managed to resell the chassis for exactly what we paid for the entire model, which was an unexpected bonus!
The built model had been glued together, so it went for a soak in paint stripper for a few days. I made a start in filing the cab and the running plate to get the engine casing to fit, but that's as far as it got. A couple of days ago I took everything out of the drawer and continued where I left off.
The replacement engine casings and the Class 02 casing for comparison, along with the running plate/valances. The previously painted one has had notches filed in it to line up with clips on the edge of the new casing.
Trial fit of the casings an the reprofiling of the buffer beams.
The filing off of the running plate lip that overhangs the valances (top) with unaltered part (bottom).
Apart from the engine casing being shorter in length and width than the Class 02 casing, the other most obvious difference between the 02 and the 220HP DE is the fuel tanks that run the length of each side of the casing and the deeper valances. These will be made as new parts and overlaid on the existing valances and lower cab sides..
The wheel diameter and base are identical on both types. My kit came with a fold-up etched chassis, whilst the other was cast whitemetal. It isn't fixable, so will be replaced by one made from scratch and as I'm building one I may as well build one for my own model.
