You joke Matt.... But on Saturday when I was exhibiting the layout I got asked the following question at least 3-4 times.Just in time for everyone to ask if it's Heljan...
Top work as usual Dave, it's nice to see the attention you give industrials.
Heljan's is of course a BR Class 02, but with their track record it wouldn't surprise me if we see some appearing in other liveries, pretending to be 220DEs. They took their Ruston LSSE (BR Class 07) and gave it the army livery but made none of the changes to the body to match the army locos (Ruston LSSH). It's like sticking the name and number of a Hall onto a Castle, telling them it's a Hall and expecting that no one will know the difference.Just in time for everyone to ask if it's Heljan...
It wasn't a very good example because, to be fair, all that GWR stuff looks much the same anyway.
Hi Tim. The two parts came apart easily, once the screws were removed. Getting the screws meant having to pull the wheels off and getting the chassis out of the body was a game in itself.Phil, goodness knows what the designer was smoking.......
Dave, did you need the little chisel to get the two halves of the chassis apart?
The rods were not tight. The holes in them were very slack but whether this was by design or wear I don't know. The rods themselves are paper-thin stampings that aren't capable of transmitting the drive so I'll replace them with scratchbuilt versions.Intersting.
In theory, if the coupling rods are nice and tight then the extra slack in the drive to the front axle (due to more gears) would cause the drive to be taken up by the centre and rear wheels (both having identical gear trains) with the gears running to the front axle running under no load.
I am. One of the problems (in my view) with the RT chassis is that all that cosmetic valve gear, con rods and slide bars are just wasted space. They can't be seen in the shadows under the boiler and that space is better used either for weight or for DCC sound gear. It's made from 15 thou. etched nickel silver, which isn't very heavy, or very strong. If I'm not going to use all the waggly bits and if I'm going to need to make my own gearbox mount anyway, I may as well make my own chassis that will be stronger and heavier.Presumably you're aware of the RT Models chassis, Dave? Just preferring to make your own?
