JimG
I find that a bit worrying! There's no way I'll use this up within 6 months! At £22 a shot that's an expensive bit of solder. Not sure I'll get domestic approval to use the fridge either, although I'll try putting it in to another container. Just makes it a faff if you need to get it to the workshop for a small bit of work.
Brian,
Here's the datasheet for the solder cream I have
http://www.datasheets360.com/pdf/-2208185409048886410
Under packaging on Page 2, you will see that it states a minimum shelf life of six months when stored sealed at 5C - 10C. If you assume a conservative element in the data sheet the shelf life for us could be a good bit more than the six months. Certainly I have been pleasantly surprised to find mine still useable after purchasing it a year ago but it has been stored in the fridge and only taken out when used. It was off Ebay and very cheap - £3.95 - so very probably being sold off at the end of its shelf life and I didn't expect it to survive too long in a useable state. My first ever syringe from Brian Lewis at C&L had to be thrown out after a year or two with only a small fraction used. I suspect that this is one of these products where the profits are in what's thrown away.
I do note that it also states in the packaging section that the product can separate with storage but can be restored to good condition by working it. I wonder if this is what I am effectively doing by puddling the cream on the end of the syringe nozzle with a cocktail stick.
I suspect that what we want is a much smaller syringe size - maybe 5g instead of 25g - so that we have a reasonable chance of cutting down on wastage. The only alternate size of container I can see are 1kg, 500g and 250g tubs.
Jim.
