Peter Insole
Sorry Tom, I haven't been back to the thread for a while so missed your reply! I've had a rummage for some pictorial memories, but I have forgotten where I put them!
Mentioning photos, it is probably about time I popped on a progress update. Although the first part was made up before the Albury show, here is the catch-up...
![SAM_x2645.JPG SAM_x2645.JPG](https://www.westernthunder.co.uk/data/attachments/66/66269-ae5e20527f51ae5a5fd55f8a97524dc0.jpg)
I needed a pair of sturdy angle brackets to support the slidebars. The originals appear to have been either cast in iron, or perhaps more likely they were forgings from the smithy?
After hunting around for a while I spotted these at our local DIY Emporium!
By a fluke, they were exactly the right width - and the outer pre-drilled hole was precisely on the centreline of the slidebar to boot! Admittedly, the legs had to be shortened and new holes drilled, but when the thickening strips were added, the redundant holes would be invisible.
![SAM_x2647.JPG SAM_x2647.JPG](https://www.westernthunder.co.uk/data/attachments/66/66272-c20aaf77e067bc3ca02ca448d415c4fa.jpg)
Just a little trim and rounding off the corners with a file needed here, before strips of MDF and ply were superglued to the steel and then drilled through for the nuts, bolts and screws.
![SAM_x2651.JPG SAM_x2651.JPG](https://www.westernthunder.co.uk/data/attachments/66/66273-3598dd3ef1d97ad3809340bb8dea6cd8.jpg)
I included ply in the top lamination to provide a bit of bite for the countersunk screw threads. Fortuitously, it also made the depth pretty much spot on into the bargain. The two bolts into the frames should be replaced with pretend rivets, so I will try and remember to pick up some more round headed bolts next time I'm near East Road in Cambridge!
Since Albury I have only managed to tinker a bit more with the motion...
![SAM_x2830.JPG SAM_x2830.JPG](https://www.westernthunder.co.uk/data/attachments/66/66274-dbbdb5d83be1a64276fb3c8903767acc.jpg)
If I'm honest, this bit was a rather time consuming trial, so shouldn't really qualify as a tinker?
I had to be extremely careful not to accidentally overcut the curves into the flat faces of the rods with the rat tail file. There were six chamfers to do in all, so plenty of opportunity to mess up?
I'm afraid I did manage to slightly nibble the fronts in a couple of places.
Thank goodness for good 'ol filler eh?
Pete.
Pete.
