What has been frightening me is that the distinctive shape of the running plates is formed of two reverse curves on a single length. The curves must fit snugly on the frames to avoid daylight showing through. Starting the bend in fractionally the wrong place could be a nightmare to adjust without leaving unsightly creases or dinks?
Plenty of opportunity to muck up then?!
I had to stop worrying, and just get on with it, so descended the stairs to the dank, dark cellar...
I started by using yet another piece of that Oak, this time making a former.
Luckily, the curves are all the same radius, though the subtly blended "S" of the risers would be the real challenge!
Whew! That first joggle was right old struggle...!
I hadn't quite thought through the design of the former, so clamping the plate between it and a batten to grip the flat sections in the vice turned into quite a juggling act!
Having to continuously undo it and offer it up to the loco, then trying to get it set again without dropping it all on the floor, or even worse; pinching a digit in the closing jaws, raised a bit of a sweat!
Then I had to commence that critical forward bend.
The stage finally reached in the above picture was followed by a brief abandonment for a sorely needed cuppa!
Only mildly refreshed and rested, the final bend of the first side was wrestled and beaten (lightly) into submission...
Although I think the front riser still needs tweaking a bit on the outside edges to better match the rear, at least the whole shebang fits without rattling.
A right Royal pain in the doodah was having to do it all again on the right hand side!
I think many would agree that I am an inveterate mutterer. By the time both plates and all eight bends were done, I imagine the whole street could have heard me loudly declare;
"I never..., never..., EVER want to do that ever again... Nope..., not no never again...!"
Now it sits, all twinkling nicely in the evening lights...
...Never again?... Hmm..., I found myself thinking;
"next time, I'll sort out the design of the former, and then maybe............!"
Pete.
