Thank you David.
Completed at last. I took these images on the garden wall in the afternoon as the lighting is better than on my bench in the garage.
It needs a few spoonfuls of coal in the tender.
Note the bent steam pipes on this side. I straightened them before taking further images below.
The valve and thin pipe above the nameplate is the steam feed for the whistle. On the real thing there is a lever on the valve that runs back to the cab behind the large pipe. This connects to the handle in the cab for operating the whistle. When I built Golden Fleece from the long defunct Acme kit some years ago, I added the lever and cable. However, it's barely noticeable on the prototype, let alone a 7mm model so I left it off this one.
This is the front end of the model build from the Acme Kit. You can see the cable behind the large pipe from this angle but mostly it's invisible. That's my excuse for being a lazy git any way!
The Acme kit can be built into a nice model of the A4 but you have to work much harder to achieve a good result than you do with the F7 kit. It was a more economical alternative to the Finney and DJH kits, and it included parts to build pretty much all variants of the A4, although not the streamlined non corridor tender. The valve gear could be made workable but the design was more complex and less builder friendly than the F7 kit so I opted for having it fixed in forward gear.
Building the boiler is more akin to ship modelling as the boiler cladding is built up around an inner skeleton/framework. Building this makes you realise just how much time and effort is saved by the F7 resin boiler!
But I digress. Here are views of the tender front and cab interior. I've just realised I've overlooked painting the boards on the tender floor! That's not an oversight by Warren as he was only required to do the main painting and lining. I painted the wheels and cab interior.
Next up I will be continuing my build of the Stanier 3P 2-6-2t from the etchings supplied by Mike Edge. I need to add the motor and pick ups and then dismantle and paint. Once that's done I need to paint my two class 4 2-6-4 tank locos, one from MOK and the other from David Andrews, so I'll be resurrecting those threads as well.
Cheers,
